Re: Weird RAM issue
[Re: 493_DART]
#3104079
12/20/22 08:34 PM
12/20/22 08:34 PM
Posts: 10,563 Freeport IL USA
poorboy
Freeport IL USA
You are correct, it should be 12 volts, off and on. Where are you picking up the ground for your test meter, through the tail light ground? Could be just a bad ground for the right side tail light assembly (everything at the taillight uses the same ground wire). The turn/brake has the most voltage and a bad ground often shows up as the voltage increases.
After the ground check, if it was mine, I would be following the wiring between the two sets of tail lights. Next if you have a trailer light connection, I would start there. Generally, the wiring comes from the front on the driver side and crosses over to the right side near the rear bed crossmember, but it often branches over to the trailer connecter on the way to the right side. If the trailer connection is good, I'd be looking for a frayed or badly corroded wire for the turn signal power to the right taillight.
Re: Weird RAM issue
[Re: poorboy]
#3104085
12/20/22 08:48 PM
12/20/22 08:48 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
Good idea -- ill check at the trailer plug . As far as ground I was probing ground pin in the plug...the rest of the lights there work fine so im doubting that ground is bad
Re: Weird RAM issue
[Re: GarageDodge]
#3104305
12/21/22 06:18 PM
12/21/22 06:18 PM
493_DART
Worst Weather USA
I'ts the board that the bulbs are plugged into,common problem,might be able to clean the prongs where bulb is plugged it. nope...the whole light assembly isnt plugged in.
Re: Weird RAM issue
[Re: 493_DART]
#3104317
12/21/22 06:45 PM
12/21/22 06:45 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Fuse box on those years is notorious for wierd issues with lights, turn signals, etc
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Weird RAM issue
[Re: GarageDodge]
#3104324
12/21/22 08:02 PM
12/21/22 08:02 PM
Posts: 4,145 Canada -- Posts: 4034 -Registe...
5thAve
I'ts the board that the bulbs are plugged into,common problem,might be able to clean the prongs where bulb is plugged it. That's what it was on my 2004 with the same problem. New board was only like $20. I'm not sure sure how it works to know there's a burnt out bulb but that could be why it's seeing 8V. Did you try pulling apart the other side to see what it does?
Re: Weird RAM issue
[Re: B3422W5]
#3104347
12/21/22 09:26 PM
12/21/22 09:26 PM
493_DART
Worst Weather USA
Fuse box on those years is notorious for wierd issues with lights, turn signals, etc Funny you mention that...i was just reading about the TIPM (fusebox) . I guess it can cause all kinds of weirdness,,,my truck has been acting strange here and there........like trying to stall , wipers turn on by themselves ...now the turn signal
Re: Weird RAM issue
[Re: 493_DART]
#3104348
12/21/22 09:31 PM
12/21/22 09:31 PM
B3422W5
Portage,michigan
Fuse box on those years is notorious for wierd issues with lights, turn signals, etc Funny you mention that...i was just reading about the TIPM (fusebox) . I guess it can cause all kinds of weirdness,,,my truck has been acting strange here and there........like trying to stall , wipers turn on by themselves ...now the turn signal All stuff you mention are things I have seen with the box. If you swap it out..make sure it is from the same year truck, there are differences between years generally. Bet a dime to a doughnut you have a fuse box corrosion issue. Extremely common. Hopefully you can find a good used one. https://repairpal.com/tipm-issues-138
Re: Weird RAM issue
[Re: B3422W5]
#3104381
12/21/22 10:59 PM
12/21/22 10:59 PM
Posts: 43,547 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I went through HELL on the TIPM, lost the right trailer light, then would lose the BUS occasionally between the cab and the engine compartment, then other lights started being intermittent. I finally got a rebuilt TIPM because no factory one's are available, got it off eBay.
JB Rhinehart, Realist
A-Body's RULE!
Re: Weird RAM issue
[Re: Cab_Burge]
#3104436
12/22/22 08:21 AM
12/22/22 08:21 AM
B3422W5
Portage,michigan
I would post this in the truck section No need now, OP should have a handle on it
Re: Weird RAM issue
[Re: GarageDodge]
#3104670
12/22/22 07:48 PM
12/22/22 07:48 PM
B3422W5
Portage,michigan
Bunch on E bay for 200 bucks or less. They aren’t that expensive
Re: Weird RAM issue
[Re: 493_DART]
#3104756
12/23/22 12:16 AM
12/23/22 12:16 AM
B3422W5
Portage,michigan
Is the TIPM just the metal module on the side of the fusebox? Or do you have to replace the entire thing ? Complete fuse box
Re: Weird RAM issue
[Re: 493_DART]
#3105328
12/24/22 08:31 PM
12/24/22 08:31 PM
B3422W5
Portage,michigan
Reset isn’t going to fix it
