Re: Torque strap question
[Re: 6PAX]
#3104276
12/21/22 04:14 PM
12/21/22 04:14 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Rubber bushing or poly in your spool mounts ?
[Re: 6PAX]
#3104292
12/21/22 04:58 PM
12/21/22 04:58 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
[Re: poorboy]
#3104541
12/22/22 12:53 PM
12/22/22 12:53 PM
Posts: 5,619 Detroit area
6PAX
Detroit area
The concept of the spool mounts were they still had some movement but couldn't completely fail. The rubber bushing failure amounts to a possible plus or minus 1/2" of movement if the rubber is completely gone. I would suppose if it hammered the metal loop long enough, it too could fail. One would hope you are paying better attention then to run the failing mount long enough to destroy the rubber completely, not even considering running it long enough for the steel loop to fail.
I would guess the answer to your question would depend on if your using your torque strap to stop all movement, or if your using it to limit movement in the event of a failure. I don't have the engine/k-frame in the car yet so the mounts haven't seen any use yet. As I mentioned, they are nos so there is no wear on them. I was just wondering if a spool mount failed, would it allow the engine to lift up out of the mount brackets and cause damage. The car is not going to be raced so I don't know what the likelihood of a spool mount failing would be.
[Re: 6PAX]
#3104676
12/22/22 08:06 PM
12/22/22 08:06 PM
Posts: 1,893 Harriman NY
71GTX471
Harriman NY
Me thinks that because spool type mounts drop straight down into the K-frame & have the metal outer sleeve that frailer would result in heavy vibrations & not the eng.lifting like previous angled style mounts.
[Re: 340SIX]
#3104826
12/23/22 10:37 AM
12/23/22 10:37 AM
Posts: 4,672 Wichita
GY3
Wichita
I like the torque strap because it completely limits movement and allows the power to transfer through the chassis quicker. I run both the strap and a solid rubber mount on the drivers side ('63 Dodge).
[Re: GY3]
#3104954
12/23/22 04:56 PM
12/23/22 04:56 PM
Posts: 8,871 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Why not just install a solid mount ??
I'm not terribly familiar with the spool mounts but couldn't you just substitute a piece of solid delrin or uhmw rod with a hole bored in it ?? That sh!t will handle the job with no problems.
[Re: Stanton]
#3105093
12/24/22 12:19 AM
12/24/22 12:19 AM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I'm not terribly familiar with the spool mounts but couldn't you just substitute a piece of solid delrin or uhmw rod with a hole bored in it ?? That sh!t will handle the job with no problems. PROTHANE and Entergy Supention allready make inserts. Everyone sells them. Summit is one source You take the old rubber out and press in the soild insert
[Re: Diplomat360]
#3105313
12/24/22 06:57 PM
12/24/22 06:57 PM
340SIX
This recommendation here is a very good one!
In preparation for the bigger torque of my W2 408 storker I used that POLY bushing kit. It was a PITA to clean-up the old stleeves, but eventually they did clean up.
The general feedback on getting these poly inserts to be squeek free is to lube them up with some silicon gel/grease prior to the install. Summit Racing sells a 3 piece kit of 3 engine mounts. The 2 fronts and the rear (Transmission) But like you say grease them well.
[Re: Cab_Burge]
#3105323
12/24/22 08:23 PM
12/24/22 08:23 PM
Posts: 12,073 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
You must hit yours a lot harder than I do mine, Cab as I have never had a problem with them loosening up. Now, I often use a long bolt for the bottom connection to the K and weld the top loop together so it can't open up. And I am sure that there are different qualities and strengths of the turn buckles.
Master, again and still
[Re: DaveRS23]
#3105363
12/25/22 03:11 AM
12/25/22 03:11 AM
Cab_Burge
I used to have to tighten the one I had up almost, not more than two races, after every race I did have it attach to a chain so maybe it was the chain stretching
[Re: 6PAX]
#3105598
12/26/22 08:42 AM
12/26/22 08:42 AM
Posts: 2,466 Answering the call of the wild
ThermoQuad
When using spool motor mounts, is a torque strap still a good thing to have or not necessary? All types of mounts with a healthy hp engine actually requires 2 of the schumaker design, based on my extensive track and burnout exhibition experience. The right side compresses even with the urethane mounts - tilting the engine & pushing the exhaust down. 4 speed cars - the clutch linkage geometry is affected as well. Any car with hp getting shock loads from burnouts, launches, high speed driving requires 2 if you want to do it correctly. A rigid mount with no give is not a good solution and either is a turn buckle. Best to use a chain with a bit of play in it unless one elects to use the proper configuration as dictated by expereince. \ The schumaker design will bolt on the passenger side with a bit of thought. That nice supercharged engine is getting shortchanged with the turn buckle.
