Squeaking/chirping in belt drive area - 5.7 Hemi #3103629
12/19/22 04:08 PM
12/19/22 04:08 PM
Alabama
W
WarEagle1 Offline OP
W
Alabama
I can't isolate this squeaking/chirping, bird-like noise at idle on an '08 Aspen, 5.7L. Only hear it after it warms up and it gets worse with some load (a/c on or sawing the wheel back and forth). It goes away at anything above idle.
I thought I had it isolated to the tensioner pulley. Changed it; didn't help. Have since changed both idler pulleys and the belt; no change. Everything felt smooth, 'normal' with the belt off.
I can't seem to isolate it with a stethoscope. Any ideas on which bearing/accessory would be most likely?
Thanks!
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: WarEagle1] #3103630
12/19/22 04:11 PM
12/19/22 04:11 PM
md
mopars4ever Offline
mopars4ever  Offline
md
If the belt is good then I would question the tensioner. When they get weak the belt can squeak.
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: WarEagle1] #3103669
12/19/22 06:21 PM
12/19/22 06:21 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I had a 1978 360 do that. It turned out to be something failed internally on the fan clutch. Replaced the clutch and
problem stopped. I'd previously replaced the belt and couldn't "feel" anything wrong with the fan clutch working it by hand,
but replacing it stopped the noise.
Rich H.
Esse Quam Videri
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: ZIPPY] #3103673
12/19/22 06:42 PM
12/19/22 06:42 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I'd feel the pulley on your water pump too and see if there's even a slight wobble. It may not be leaking yet but be getting weak.
Facts are stubborn things.
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: ZIPPY] #3103674
12/19/22 06:43 PM
12/19/22 06:43 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Electric fans shruggy
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: larrymopar360] #3103716
12/19/22 08:21 PM
12/19/22 08:21 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Most likely this guy is the winner. I wish I had the patience to post a video, I took one after the pump started to let go on a 5.7 in a grand cherokee. No difference in operating temps, just an occasional squeel or chirp. Very embarrassing when picking the kids up from school
Also, take the belt off and run it for a few seconds...
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: moparjim79] #3103763
12/19/22 10:19 PM
12/19/22 10:19 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The belt tensioner was causing intermittent squealing on my son's 5.7. It wasn't always keeping the belt tight. I've seen this on 3 other various year and drive train Mopars recently. Defective belt tensioners.
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: poorboy] #3103849
12/20/22 09:53 AM
12/20/22 09:53 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
He said he replaced both.
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: larrymopar360] #3103866
12/20/22 10:31 AM
12/20/22 10:31 AM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Get a mechanic's stethoscope and start listening to various thing. No sense spending money you do not need to.
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: Sniper] #3103943
12/20/22 02:07 PM
12/20/22 02:07 PM
ca
N
nick24 Offline
nick24  Offline
N
ca
From orig. post: I can't seem to isolate it with a stethoscope.
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: Sniper] #3103954
12/20/22 02:28 PM
12/20/22 02:28 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Or a pry bar or long screwdriver that has metal to the top of the handle.
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: larrymopar360] #3103978
12/20/22 03:36 PM
12/20/22 03:36 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Said he replaced the tensioner pulley and the idler pulley, nothing about the tensioner itself. They sell a kit that has both pulleys with the bearings, but does not replace the tensioner spring assembly itself.
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: poorboy] #3104056
12/20/22 07:39 PM
12/20/22 07:39 PM
Alabama
W
W
Alabama
Hey guys,
Thanks for all the responses.
I did replace the tensioner pulley but not the whole tensioner assembly. May have been a mistake there. I pushed down on it slightly with a stick of wood (while running) to simulate a tighter spring and don't think it improved it. I'll look at it again.
Not sure running it without the belt would tell me anything. None of the possible offenders would be turning smile
I'll recheck the water pump for any slop. Did this earlier and didn't notice anything amiss, but I'll make sure there's ZERO play.
Any other ideas or experiences are appreciated.
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: WarEagle1] #3104057
12/20/22 07:44 PM
12/20/22 07:44 PM
Alabama
W
W
Alabama
Oh. The fan clutch reply is interesting too. It does have a mechanical fan.
Has anyone had noise from their fan clutch on a Gen 3 Hemi?
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: WarEagle1] #3104146
12/20/22 11:26 PM
12/20/22 11:26 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
My truck is an '01 Ram with a 5.2. In my experience, belts are horrible these days.
About a decade ago I had a squeal that I would have bet money was coming from my A/C pump. Took my truck to a local guy that I trusted, opened the hood and he said "that's your belt." NO WAY...it's less than a year old! He put some soap on it to prove it to me...
I think Sniper has the right answer. IF it's something other than the belt, a stethoscope might save you some money...
EDIT: BTW, I now use "lifetime" AC Delco belts (from Rock Auto) that last about 3 years, and I'm OK with that.
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: WarEagle1] #3108018
01/03/23 02:33 PM
01/03/23 02:33 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yes..a general rule of thumb the trucks usually have a belt driven fan, the cars have electric.
Not sure, usually it's a tensioner or similar on a serpentine, but just throwing the idea out there since it's a possibility.
good luck
Rich H.
Esse Quam Videri
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: ZIPPY] #3108196
01/03/23 04:52 PM
01/03/23 04:52 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Still say it is the tensioner. I had one drive me crazy until I replaced it.
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: Fat_Mike] #3108300
01/03/23 10:19 PM
01/03/23 10:19 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
So, have you replaced the entire belt tensioner, or do you still think the original tensioner is OK and all those belts were the problem? I have serpentine belts that are over 6 years old that do not squeal. I have replaced a few belt tensioners though. After 5 or 6 years, the coil spring and the free movement in the tensioners don't function like they were designed to work, especially in the limited movement area they usually operate in.
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: poorboy] #3108307
01/03/23 11:22 PM
01/03/23 11:22 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Get a Good Year Gatorback belt. It stopped my squealing belt problem.
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: poorboy] #3108324
01/04/23 12:10 AM
01/04/23 12:10 AM
N.W. Florida
N.W. Florida
Yes. Well...remembering back (and knowing me) I'm certain I went through all that before I searched for outside help. It's possible that I missed something, but there ain't much to miss. shruggy When (not if) the chirp re-appears I'll address it without assumptions. Thanks...I needed that nudge.
Do you have a specific brand of tensioner that you run?
