heads/brake booster #3103507
12/19/22 08:19 AM
12/19/22 08:19 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
69 b-body 440 with indy ez heads.will a power brake booster fit without interferance with the head or v-cover
Re: heads/brake booster [Re: bonefish] #3103508
12/19/22 08:26 AM
12/19/22 08:26 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Yes. The 69 GTX was equipt that way and EZ heads shouldn't make much difference at all.You could go to the aftermarket for a smaller boosterif you want more room.
1969 Hemi Roadrunner 2nd owner
Re: heads/brake booster [Re: 69hemibeep] #3103695
12/19/22 07:32 PM
12/19/22 07:32 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
thanks,i have a booster that came off a Ebody,it measures about 8 inches.would it be the same as a b- body booster?
