Page 3 of 4 1 2 3 4
Re: 11/16 tie rod upgrade, what are the benefits? [Re: AndyF] #3054938
07/01/22 12:55 PM
07/01/22 12:55 PM
moparx Offline
moparx  Offline
i too, always thought cost was the main reason, and strength was just along for the ride.
beer
Re: 11/16 tie rod upgrade, what are the benefits? [Re: Kern Dog] #3054950
07/01/22 02:28 PM
07/01/22 02:28 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Kern Dog -- Regarding boxing the LCA, I wonder how much that is truly worth ... the race Posey T/A and Gurney AAR cars do not have them boxed... maybe SCCA TransAm rules never allowed that to be done. I've boxed my LCAs and run the 11/16" tie rods, and have the K-frame all reinforced... can't tell if it has made any difference (running competition pylon autocross, as well as HPDE/HSAX)... I suppose better to have it done vs not done.
Re: 11/16 tie rod upgrade, what are the benefits? [Re: Mopar Mitch] #3054979
07/01/22 04:57 PM
07/01/22 04:57 PM
AndyF Offline
AndyF  Offline
I know that boxing the LCA is important when using a big anti-sway bar, especially the early ones with the sway bar mount out on the end of the LCA. The force from the sway bar is enough to spread the LCA apart if it isn't boxed.
Re: 11/16 tie rod upgrade, what are the benefits? [Re: AndyF] #3054985
07/01/22 06:04 PM
07/01/22 06:04 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
One other thing to consider, the longer the tie rod assembly the more likely it is to bend. So you up the diameter
My 51 has a real short driver's side assembly, about a foot. The pass side is about three feet long work
Yeah, bumpsteer is a thing
Re: 11/16 tie rod upgrade, what are the benefits? [Re: Sniper] #3055127
07/02/22 06:43 AM
07/02/22 06:43 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
many benefits no deficits to upgrading the larger hardware other than the wallet
Use the solid aftermarket ones.
same with boxing the LCAs, aftermarket UCA's, firm feel sway bars/steering, strut rods, etc......................
I spent 22+ yrs running hot laps in high performance driving schools on Thunder Road, this is not autocross, one step less than racing, I had a car that could run with the big dogs if i wanted too. Watkins Glen 2x per yr 2days per event
Do the math
At each and every 2 day event there were always upgrades that significantly lowered my lap times to the pt i was running under the "number" which is 2.5 minutes for a full lap.
I have had a lot of tech support esp at the track.
If anyone want to ask me what works and wants to tune the suspension let alone a six pak please pm me ....I have data not the seat of my pants
Re: 11/16 tie rod upgrade, what are the benefits? [Re: AndyF] #3056404
07/05/22 05:18 PM
07/05/22 05:18 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Originally Posted by AndyF
It is a classic mopar debate. Just like regular or high volume oil pumps. LH wheel studs or regular ones, Dana 60 vs Ford 9 inch, etc.
People still question a 9" over a 60?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 11/16 tie rod upgrade, what are the benefits? [Re: astjp2] #3101565
12/12/22 01:15 PM
12/12/22 01:15 PM
High Plains of South Dakota
O
olwhite64 Offline
olwhite64  Offline
O
I see this is a bit of a hot-button, but my question should be pretty straighforward as I'm dong the upgrade on my '71 Roadrunner, regardless of opinions:
I plan on ordering a set of inner/out tie rods for a 1970 Newport; does anybody know the part number for a set of billet sleeves? Proforged, PST, etc. - brand doesn't really matter to me as they all seem to be relatively priced the same ($60-ish bucks)?
Re: 11/16 tie rod upgrade, what are the benefits? [Re: olwhite64] #3101762
12/12/22 10:46 PM
12/12/22 10:46 PM
AndyF Offline
AndyF  Offline
The prices might be the same but they don't all work properly. I had Firm Fell adjusters on my Coronet but they were too long so I had to switch to PST adjusters.
Re: 11/16 tie rod upgrade, what are the benefits? [Re: AndyF] #3102410
12/14/22 09:57 PM
12/14/22 09:57 PM
IL
8
83hurstguy Offline
83hurstguy  Offline
IL
I always thought the point I made early in this thread was the most valid reason to upgrade and that was cost. I'm not sure if this is still true, but for a long time the C body ends and adjusters were less expensive than the ABE parts. So it was actually cheaper to install the factory 11/16 parts than to replace the stock parts. If they were also stronger then double win.
The cheaper reason was still true earlier this year when I bought parts, and it was a pretty noticeable difference. 11/16 parts seemed to make more sense...
Re: 11/16 tie rod upgrade, what are the benefits? [Re: 83hurstguy] #3102592
12/15/22 03:57 PM
12/15/22 03:57 PM
moparx Offline
moparx  Offline
i just did a quick rock auto search, and that seems not to be the case any more. i always thought the 11/16 chrysler items were cheaper as well.
using moog for my search.
chysler tie rod - $15.34, and adjuster sleeve - $14.24
dodge tie rod - $13.78, adjuster sleeve - $11.86
so who knows ? shruggy
beer
Re: 11/16 tie rod upgrade, what are the benefits? [Re: moparx] #3102700
12/15/22 09:28 PM
12/15/22 09:28 PM
IL
8
83hurstguy Offline
83hurstguy  Offline
IL
Check proforged prices... they make pretty good stuff. $20 or less on the 11/16, over $40 on the 9/16.
Re: 11/16 tie rod upgrade, what are the benefits? [Re: 83hurstguy] #3102853
12/16/22 01:27 PM
12/16/22 01:27 PM
moparx Offline
moparx  Offline
i keep forgetting about the pro forge stuff !
i have been very disappointed in moog stuff for many years because of the downgrade in quality.
however, i haven't had the need to replace anything on my own car, so my moog experience is strictly by installing moog parts brought to me for installation on other's vehicles.
beer
Re: 11/16 tie rod upgrade, what are the benefits? [Re: moparx] #3106252
12/29/22 12:40 AM
12/29/22 12:40 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
I guarantee the greatest force on those tie rods is when parallel parking in a tight spot.
Re: 11/16 tie rod upgrade, what are the benefits? [Re: moparx] #3106253
12/29/22 12:42 AM
12/29/22 12:42 AM
Seattle, WA
3
375inStroke Offline
375inStroke  Offline
3
Seattle, WA
beer
Strange. I show $30.79 for the Dodge tie rod ends.
Re: 11/16 tie rod upgrade, what are the benefits? [Re: 375inStroke] #3108231
01/03/23 06:29 PM
01/03/23 06:29 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
beer
Lots of places price according to zip code, so that may play into it?
'63 Dodge 330
11.19 @ 121 mph
Re: 11/16 tie rod upgrade, what are the benefits? [Re: 375inStroke] #3115568
01/23/23 01:19 AM
01/23/23 01:19 AM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
With a BB , wide tires, and not rolling, wonder if anyone can feel the difference? LOL
Re: 11/16 tie rod upgrade, what are the benefits? [Re: jcc] #3130806
03/20/23 12:31 PM
03/20/23 12:31 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
This IMO should not go unshared. I've leave my conclusions out.
Last weekend at Sebring Corvette had a C8 cutaway on display among others. What caught my eye was the unmentioned/unnoted front wheel AWD? drivetrain.
But what I saw in the attached pic to this thread also is pertinent.
So keep in mind, this is a 60 year newer design chassis then our cars, its weight is approx 3600lbs w/o driver, it is an OEM daily street car, potentially over $100K, 670hp, pulls 1.03g on skid pad, has a nearly 50/50 weight balance with driver, tops out stock at 184mph, has a front tire 275/30x20 with electric PS, and appears to use a 1/2-9/16" steering tie rod which I did not measure.
Re: 11/16 tie rod upgrade, what are the benefits? [Re: jcc] #3130885
03/20/23 03:24 PM
03/20/23 03:24 PM
moparx Offline
moparx  Offline
that does look rather tiny, compared to what one would expect from a vehicle capable of way more handling prowess than our rides.
could that be 13, 14, or 15mm thread instead of UNF thread size ?
i have always wondered how OEM's decide on, or test for, thread/bolt size per application, as i know about thread strength in shear applications, and always seem to want to go way more/larger than necessary so as to ensure myself the bolt/thread size will not cause problems in the application i am contemplating.
beer
Re: 11/16 tie rod upgrade, what are the benefits? [Re: moparx] #3130910
03/20/23 05:25 PM
03/20/23 05:25 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
I use 14mm wheel studs, and it was it definitely did not even "look" 14mm (9/16"), but the main point here is that it was not 11/16"
Re: 11/16 tie rod upgrade, what are the benefits? [Re: jcc] #3131118
03/21/23 01:47 PM
03/21/23 01:47 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Those are solid though on the inner
I would think that is much stronger than the factory rolled/formed sheet steel that get threaded.
The outer is solid then threaded hole at end. But it's a forged end and thicker then our OE rolled steel ones.
Page 3 of 4 1 2 3 4
