Re: SPEAKER REPAIR
[Re: TJP]
#3101585
12/12/22 01:42 PM
12/12/22 01:42 PM
Posts: 3,528 Lansing, MI
70gtx440dana
Lansing, MI
I used to use Jackson speaker as well. I now send my stuff to Utah Speaker Reconing:
Utah Reconing
Phone 801-419-3099 redmatt2@juno.com
Address Utah 84084 United States
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: SPEAKER REPAIR
[Re: superbird]
#3101716
12/12/22 08:48 PM
12/12/22 08:48 PM
Posts: 8,409 Highland, MI.
Sunroofcuda
Highland, MI.
Superbird - REPLACE it with something new & better quality. Use a 4 ohm for a car radio. Check out the speakers from these guys - you'll need a COAXIAL speaker. They come in many sizes: www.parts-express.com
Re: SPEAKER REPAIR
[Re: Sunroofcuda]
#3103091
12/17/22 01:04 PM
12/17/22 01:04 PM
Posts: 2,957 GA
roadrunninMark
GA
Superbird - REPLACE it with something new & better quality. Use a 4 ohm for a car radio. Check out the speakers from these guys - you'll need a COAXIAL speaker. They come in many sizes: www.parts-express.com Sunroof… that site looks pretty good. Can you tell us what speakers you used? I have the 3 speaker dash in the e body so I am looking for a modern sound setup that will fit. In the back, 6 x 9 should be easy to select. I want to upgrade to a 4 channel system.
Re: SPEAKER REPAIR
[Re: roadrunninMark]
#3103175
12/17/22 08:12 PM
12/17/22 08:12 PM
Posts: 1,757 Phila
PhillyRag
Phila
Superbird - REPLACE it with something new & better quality. Use a 4 ohm for a car radio. Check out the speakers from these guys - you'll need a COAXIAL speaker. They come in many sizes: www.parts-express.com Sunroof… that site looks pretty good. Can you tell us what speakers you used? I have the 3 speaker dash in the e body so I am looking for a modern sound setup that will fit. In the back, 6 x 9 should be easy to select. I want to upgrade to a 4 channel system. Any decent power speaker for the outer's will have a larger dia. magnet. Factory used those narrow magnets. Therefore you have to enlarge opening in the metal dash frame to accommodate. Used some nice sparkomatic's on my 73-E & needed to modify metal below, but fit the grilles nice. Center spot I just left old in not connected, not really needed with a 4 speaker setup..
Re: SPEAKER REPAIR
#3103186
12/17/22 08:49 PM
12/17/22 08:49 PM
Sunroofcuda
Highland, MI.
Superbird - REPLACE it with something new & better quality. Use a 4 ohm for a car radio. Check out the speakers from these guys - you'll need a COAXIAL speaker. They come in many sizes: www.parts-express.com Sunroof… that site looks pretty good. Can you tell us what speakers you used? I have the 3 speaker dash in the e body so I am looking for a modern sound setup that will fit. In the back, 6 x 9 should be easy to select. I want to upgrade to a 4 channel system. RRMark, I'll look into this more for you. The rears (6x9) will be easy to select, but the fronts will be more tricky with their profile. PLUS, you want all the speakers to be full-range (co-axial). Anyway, I'll look. Parts Express used to have a much more comprehensive lineup - and they used to have a couple pages that showed speaker listings along with dimensions & bolt patterns. I'll look in one of their older printed catalogs that had all this.
Re: SPEAKER REPAIR
[Re: Sunroofcuda]
#3103601
12/19/22 02:34 PM
12/19/22 02:34 PM
Posts: 2,957 GA
roadrunninMark
GA
Superbird - REPLACE it with something new & better quality. Use a 4 ohm for a car radio. Check out the speakers from these guys - you'll need a COAXIAL speaker. They come in many sizes: www.parts-express.com Sunroof… that site looks pretty good. Can you tell us what speakers you used? I have the 3 speaker dash in the e body so I am looking for a modern sound setup that will fit. In the back, 6 x 9 should be easy to select. I want to upgrade to a 4 channel system. RRMark, I'll look into this more for you. The rears (6x9) will be easy to select, but the fronts will be more tricky with their profile. PLUS, you want all the speakers to be full-range (co-axial). Anyway, I'll look. Parts Express used to have a much more comprehensive lineup - and they used to have a couple pages that showed speaker listings along with dimensions & bolt patterns. I'll look in one of their older printed catalogs that had all this. Thank you!! You can send a PM if you want also, don't want to highjack thread.
Re: SPEAKER REPAIR
#3221695
03/20/24 04:11 PM
03/20/24 04:11 PM
70gtx440dana
Lansing, MI
I am hearing that Jackson Speaker Service is actually in business. Seems he dropped his land line a few years ago and did not publish the cell # for contact.
Address: 3921 Pine Crest Ct, Jackson, MI 49203 Phone: (517) 740-0092
