Quick release #3101285
12/11/22 12:47 PM
12/11/22 12:47 PM
Indianapolis Indiana
Jamie340 Offline OP
Jamie340  Offline OP
I am looking for recommendations for quick release hub for a 1971 Dodge Dart steering wheel. Any thoughts please share.
Thank you
Jamie D/SA 1971 Demon340
Re: Quick release [Re: Jamie340] #3101353
12/11/22 04:27 PM
12/11/22 04:27 PM
NY
challenger451ci Offline
NY
I made a column and bolted a Strange quick release hub to my factory E body wheel.
Re: Quick release [Re: challenger451ci] #3101405
12/11/22 07:45 PM
12/11/22 07:45 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Strange.
Re: Quick release [Re: CMcAllister] #3101958
12/13/22 02:55 PM
12/13/22 02:55 PM
moparx Online content
moparx  Online Content
my humpback, using a tilt/telescopic knuckle and the turn signal switch only, from a 1978 New Yorker saginaw column.
i fabricated the rest of the column.
the removable connector was a modified hex dirt track [speedway brand i think] connector, to include a horn wire, plus a slightly longer [and stronger] disconnect pin.
beer
Re: Quick release [Re: moparx] #3101960
12/13/22 03:02 PM
12/13/22 03:02 PM
more.............
the wheel bolted on has a plate installed where the horn button will reside. this is just temporary until i decide what i want for a horn button.
i forgot to add, i also used the stainless sliding collar from the New Yorker, and used the "pointy" style tilt and turn signal knobs from a 66/67ish coronet [?] column.
beer
