Mike Murillo fire
#3100449
12/07/22 03:38 PM
12/07/22 03:38 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I watched the NPK when Mike's Mustang caught on fire and he was struggling with the fire system actuator cable. I cant understand why these guys don't pull the pin before staging the car. Now I don't have a fire system on my 10 second bracket car but maybe I should think about installing one with the guidance of Tim Mcamis. Here is the vid Tim has produced with some very good information that may have reduced the damage to Mikes racecar. https://www.youtube.com/watch?v=17vbg_iqgEsGus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Mike Murillo fire
[Re: fourgearsavoy]
#3100451
12/07/22 03:42 PM
12/07/22 03:42 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
I've had a on board fire system that I have never used with 5 sprayers, three in the engine compartment and two in the driver compartment, that I will install in my new heads up no prep supercharge E85 car now, thanks for posting your post if I'm remembering correctly he had a hard time unfastening the drivers seat belt 5 point safety harness trying to get out of the car also My new car will have the higher priced hit to release cam lock latch driver harness, not the standard cheaper mechanical pull and push latch I'll will always cock it also after hooking it up, arm it, so it releases quickly also
[Re: Cab_Burge]
#3100456
12/07/22 03:57 PM
12/07/22 03:57 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Mike like the most of us isn’t in the best physical shape as we get older. We could all do better at getting ourselves in better shape.
[Re: fourgearsavoy]
#3100491
12/07/22 06:22 PM
12/07/22 06:22 PM
Posts: 716 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Mike made a facebook post about this, right after it happened. Basically, the pin is in it because the system had accidentally been fired off a couple of times. So they put a flag on the pin that he could easily reach from the driver's seat. The plan was to pull the flag, then activate the system, the problem was the pin got bent, and when he pulled the flag it ripped off, and he can't reach the pin from his seat. He also showed pics that were taken, of the inside of the car, from the night before and the pin wasn't bent. He also took full responsibility for all of it.
Joe
Without Data, you’re just another guy with an opinion.
[Re: topside]
#3100520
12/07/22 08:43 PM
12/07/22 08:43 PM
Posts: 4,585 Motor City
6PKRTSE
Motor City
I have an on board fire system in my Challenger with 6 spray nozzles. 3 in the engine compartment and 3 pointing at me towards the driver seat. I have the bottle mounted behind my driver's seat on the horizontal cage bar.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3100523
12/07/22 08:52 PM
12/07/22 08:52 PM
Posts: 20,217 Park Forest, IL
slantzilla
Park Forest, IL
Big Country Swanstrom got him out of the car. The track crew looked woefully unprepared.
[Re: pittsburghracer]
#3101120
12/10/22 06:05 PM
12/10/22 06:05 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
It has been at least 30 years since I last spoke to him when I lived in San Antonio. Yes, he was probably 175 lbs back then!
