Mike Murillo fire #3100449
12/07/22 03:38 PM
12/07/22 03:38 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
I watched the NPK when Mike's Mustang caught on fire and he was struggling with the fire system actuator cable. I cant understand why these guys don't pull the pin before staging the car. Now I don't have a fire system on my 10 second bracket car but maybe I should think about installing one with the guidance of Tim Mcamis.
Here is the vid Tim has produced with some very good information that may have reduced the damage to Mikes racecar. https://www.youtube.com/watch?v=17vbg_iqgEs
Gus beer
64 Plymouth Savoy
Dana 60
Re: Mike Murillo fire [Re: fourgearsavoy] #3100451
12/07/22 03:42 PM
12/07/22 03:42 PM
I've had a on board fire system that I have never used with 5 sprayers, three in the engine compartment and two in the driver compartment, that I will install in my new heads up no prep supercharge E85 car now, thanks for posting your post bow up
if I'm remembering correctly he had a hard time unfastening the drivers seat belt 5 point safety harness trying to get out of the car also shock
My new car will have the higher priced hit to release cam lock latch driver harness, not the standard cheaper mechanical pull and push latch work I'll will always cock it also after hooking it up, arm it, so it releases quickly also up work
Re: Mike Murillo fire [Re: Cab_Burge] #3100456
12/07/22 03:57 PM
12/07/22 03:57 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Mike like the most of us isn’t in the best physical shape as we get older. We could all do better at getting ourselves in better shape.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Mike Murillo fire [Re: pittsburghracer] #3100459
12/07/22 04:04 PM
12/07/22 04:04 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Didn’t he have trouble unbuckling? Thought he did. If the fire system didn’t go off he should’ve gotten out in a couple seconds, his life is more important than the car.
Re: Mike Murillo fire [Re: fourgearsavoy] #3100491
12/07/22 06:22 PM
12/07/22 06:22 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Mike made a facebook post about this, right after it happened. Basically, the pin is in it because the system had accidentally been fired off a couple of times. So they put a flag on the pin that he could easily reach from the driver's seat. The plan was to pull the flag, then activate the system, the problem was the pin got bent, and when he pulled the flag it ripped off, and he can't reach the pin from his seat. He also showed pics that were taken, of the inside of the car, from the night before and the pin wasn't bent. He also took full responsibility for all of it.
Joe
Without Data, you’re just another guy with an opinion.
Re: Mike Murillo fire [Re: sr4440] #3100506
12/07/22 07:39 PM
12/07/22 07:39 PM
birdtracker Offline
birdtracker  Offline
some thing to think about. I have practiced getting unbuckled and out in an emergency. Birdtracker
Re: Mike Murillo fire [Re: birdtracker] #3100514
12/07/22 08:05 PM
12/07/22 08:05 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ Yup, me too.
I like the turn-the-knob-to-release style of belts myself, never liked the "assemble & lever" style.
I'm thinking the fire system deal was placed there so it couldn't be bumped & set off during between-rounds thrashing, but needs re-thinking.
Maybe something nearer the shifter, or somewhere easily accessible but not in the way of maintenance ?
That was rather startling to watch - and seemed like a lot of smoke inhalation while wrestling the harness.
Re: Mike Murillo fire [Re: topside] #3100520
12/07/22 08:43 PM
12/07/22 08:43 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have an on board fire system in my Challenger with 6 spray nozzles. 3 in the engine compartment and 3 pointing at me towards the driver seat. I have the bottle mounted behind my driver's seat on the horizontal cage bar.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Mike Murillo fire [Re: 6PKRTSE] #3100523
12/07/22 08:52 PM
12/07/22 08:52 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Big Country Swanstrom got him out of the car. The track crew looked woefully unprepared.
Re: Mike Murillo fire [Re: slantzilla] #3100543
12/07/22 10:47 PM
12/07/22 10:47 PM
Did I tell you I hate that guy rant
That being said I'm glad he has not hurt himself racing, boogie Yet work shruggy
Somebody in that family must have a lot of money to support his racing work shruggy
Re: Mike Murillo fire [Re: Cab_Burge] #3100627
12/08/22 12:38 PM
12/08/22 12:38 PM
my own world
theraif Offline
theraif  Offline
my own world
Re: Mike Murillo fire [Re: pittsburghracer] #3101120
12/10/22 06:05 PM
12/10/22 06:05 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
It has been at least 30 years since I last spoke to him when I lived in San Antonio. Yes, he was probably 175 lbs back then!
