Page 2 of 3 1 2 3
Re: Cross Ram - inside work - dividers / block offs..... [Re: theclutcher] #310022
05/07/09 01:46 PM
05/07/09 01:46 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
expensive solution: multipoint EFI with twin TB's and the fuel rails/injectors internal to the cross ram. gets rid of a lot of wet-flow fuel distribution problems
2017 Grand Cherokee Overland
Re: Cross Ram - inside work - dividers / block offs..... [Re: theclutcher] #310023
05/07/09 01:53 PM
05/07/09 01:53 PM
...gently down the stream
LAR_414 Offline OP
LAR_414  Offline OP
I would like to go MPFI....that would be sweet and cool...but that's beyond me and my $$.
The way this intake is designed, I'd have to separate the right and left cylinders, not the front and back ones.
Each carb sits over the ports for the opposite bank.
Re: Cross Ram - inside work - dividers / block offs..... [Re: patrick] #310024
05/07/09 02:02 PM
05/07/09 02:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
there was a setup in a mag recently like that , multi point FI on a croaaram hemi , injectors and plumbing in the intake , to air horn throttle bodies on the top.
Larry , you have 1300 cfm on a 408ish inch engine ? I would think a smaller pair of carbs as a test would be the first test ?
Re: Cross Ram - inside work - dividers / block offs..... [Re: JohnRR] #310025
05/07/09 02:16 PM
05/07/09 02:16 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I have a combined 780 cfm on my 360 and can idle at 700 rpm in drive - ( 2 holley 390's) but the tunnel ram dont have all those turns like a cross ram does, so fuel suspension is less of a problem for me
Re: Cross Ram - inside work - dividers / block offs..... [Re: DJVCuda] #310026
05/07/09 02:21 PM
05/07/09 02:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Dave 780 on the tunnel ram is like having a thermobog on a dual plane on your 360.
Re: Cross Ram - inside work - dividers / block offs..... [Re: DJVCuda] #310027
05/07/09 02:26 PM
05/07/09 02:26 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I'm the guy that did the crossram EFI conversion with everything hid inside. I have done about 6 of these now and they all work pretty darn well (if I do say so myself).
You can go to my web site(www.fastmanefi.com), click on "Photos" and scroll down past the Yellow E-Body to see lots of internal pictures.
Re: Cross Ram - inside work - dividers / block offs..... [Re: JohnRR] #310028
05/07/09 02:29 PM
05/07/09 02:29 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
yup - only faster!
12.56 @ 106 compares to a stock ported iron intake and 780 cfm holley at 13.2 @102
Re: Cross Ram - inside work - dividers / block offs..... [Re: Mopar_Rich] #310029
05/07/09 02:30 PM
05/07/09 02:30 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Here's a shot from one of my customers.
BTW: The fuel rails are actually above the intake ports so they don't have much affect on max HP. I dynoed the first Hemi at 675 HP with carbs on the same manifold. After conversion the engine actually made a little more HP on EFI, but that was because I was able to individually tune each cylinder independently.
Re: Cross Ram - inside work - dividers / block offs..... [Re: LAR_414] #310030
05/07/09 02:49 PM
05/07/09 02:49 PM
LAR_414 Offline OP
LAR_414  Offline OP
Wow that's some sweet work there on the EFI. That is sure nice. I'm sure it would be a challenge to get it inside this intake. Here's a pic, during mockup, before any damn's and such.
On the carbs, No sense trying smaller ones. It's not overcarbed. Even though theres not sure fire way to pick CFM for an engine, I'm in the ball park.
Remember, the carbs are rated at 1.5inches of vacuum. At WOT, you better not be pulling that kind of vacuum, or you have a major restriction. Assume your pulling 3/4 of an inch. A (rated 650 carb at 1.5 inches of vacuum), probably flows more like 450 cfm at 3/4 inch draw. Two of those is about 900cfm. My engine at 414 cubes and 6500rpm should need about 800 cfm at 100%VE. I'm Good!
Re: Cross Ram - inside work - dividers / block offs..... [Re: Mopar_Rich] #310031
05/07/09 04:37 PM
05/07/09 04:37 PM
wappinger falls new york
Jimi_Vignogna Offline
rich your work is awesome!!!! i love the cross ram hemi
Re: Cross Ram - inside work - dividers / block offs..... [Re: LAR_414] #310032
05/07/09 05:15 PM
05/07/09 05:15 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I never tried one of those manifolds. The issue would be the vertical distance from the runners to the cover.
The biggest problem with the EFI conversion is the cost. Not only are the manifolds expensive but you have to commit to the entire EFI process. NOT for the weak of heart.
I don't have much input to your basic problem with the carbs. Sorry.
Re: Cross Ram - inside work - dividers / block offs..... [Re: LAR_414] #310033
05/07/09 08:23 PM
05/07/09 08:23 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Maybe a spread bore type carbs? I know it would be work to fit them on that intake(spacer/adapter?)Smaller primarys(better signal/velocity)but still the CFM you need at WOT.Just a thought? I've been watching this thread as I have the same problem(as I said in your Q&A post),great reading BTW!!Please let us know what you find as I'm sure there are other members who have the same issues with low speed drivability.
Re: Cross Ram - inside work - dividers / block offs..... [Re: theclutcher] #310034
05/07/09 08:45 PM
05/07/09 08:45 PM
Fort Morgan
1OFNONE Offline
Has been a member for quite a few years, so relax.
1OFNONE  Offline
Fort Morgan
I spoke with Damon at Diamondback Engines in Texas who is the current foremost authority on these intakes. He told me to put a 1" 4 hole spacer under each carb. That made a huge difference.
Next he said to put a 1/4 " spacer between the lid and the bottom to increase the radious the fuel has to turn in due to it just slams into the bottom of the plenium. I never did that cause the spacers cured my drivablity issues.
Call him and pick his brain. Very smart man.
Thats my 10 cents.
So the bartender says to the horse " Gee, Why the long face?"
Re: Cross Ram - inside work - dividers / block offs..... [Re: 1OFNONE] #310035
05/08/09 07:57 AM
05/08/09 07:57 AM
LAR_414 Offline OP
LAR_414  Offline OP
I'm glad to hear that a 4 hole spacer made a huge difference. What EXACTLY was the issue that it helped with? THis obviously seems like the easiest thing to try (although I need to buy spacers and longer carb studs).
Re: Cross Ram - inside work - dividers / block offs..... [Re: LAR_414] #310036
05/08/09 08:34 AM
05/08/09 08:34 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
weak signal to carb caused by huge plenum.
Re: Cross Ram - inside work - dividers / block offs..... [Re: LAR_414] #310037
05/08/09 09:49 AM
05/08/09 09:49 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Thats what I'd do, then adjust hgt. as needed,
could almost do that on car.
After trying the 4 hole spacers...
Re: Cross Ram - inside work - dividers / block offs..... [Re: theclutcher] #310038
05/08/09 10:24 AM
05/08/09 10:24 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
This morning I did a dyno tune on a 68 hemi dart with the mopar cross ram. It was weird that this thing did not have the typical surging idle. When I went to pull the carbs to do some jetting bingo there was a 4 hole spacer. Maybe we are on to somthing. Jake
JAKES AUTOMOTIVE
Re: Cross Ram - inside work - dividers / block offs..... [Re: JAKE68] #310039
05/08/09 10:33 AM
05/08/09 10:33 AM
LAR_414 Offline OP
LAR_414  Offline OP
Gentlemen,
Thanks for the healthy discussion here. I think we all gained something.
I think the first thing I'll do (when time allows) is to get a couple of four hole 1" tall spacers and get them on there. Got to modify some linkage and the fuel lines a tad, and make sure there is enough hood clearance (no hoodscoop).
I'll report back, on what that does, but it might take me while to actually get time to do this.
If that doesn't do it, then I'll probably pop the top and try modifiying the inside of the intake. Take out some plenum volume, and /or modify the area under the carbs to get rid of the "valley" channel. Make more of a dome there.
I can separate the two sides of the intake more, and just leave a little balancing opening/tube. Maybe make that opening adjustible too.
Re: Cross Ram - inside work - dividers / block offs..... [Re: JAKE68] #310040
05/08/09 01:05 PM
05/08/09 01:05 PM
GomangoCuda Offline
GomangoCuda  Offline
Didn't ALL of the Mopar Mag and Aluminum, maxwedge and Hemi crossrams have 4 hole carb mountings instead of the square holes that the STR intake has?
Re: Cross Ram - inside work - dividers / block offs..... [Re: LAR_414] #310041
05/08/09 02:05 PM
05/08/09 02:05 PM
GomangoCuda Offline
GomangoCuda  Offline
I have an intake that almost nobody has messed with.....and I like it that way
It's a STR-12 for a smallblock.
I like being different also so I won't try to talk you out of trying to tame the STR but here is my limited experience with one. I had an STR crossram for a 440 back in the day. I called Edelbrock to ask what I should try for carbs (I was thinking crossram Hemi Holleys). The guy I talked to there said to sell the STR to a guy with a show car and buy a TM7 (Tarantula) and a 4781 850DP Holley. He said the TM7 850 combo was a lot cheaper and worth 10 HP over the STR without the drivability issues of the STR. He said I would hate the STR lol. I could have issues with fuel puddling, plenum explosions and broken lids. IIRC he said it wouldn't be happy below 3500 RPM, it would be all over before 6500 RPM and don't even try to use it without the Baddest MSD ignition available. Sooo I sold the STR unused to guy that was putting a 440 into a 57 Chevy (Honest, I couldn't make this up!) and bought the TM7 and 4781.
Page 2 of 3 1 2 3
