OE Tie rod boot replacement # 2835896? #3100065
12/06/22 11:09 AM
12/06/22 11:09 AM
md
mopars4ever Offline OP
md
Does anyone reproduce the tie rod replacement boots? Mopar part 2835896
Re: OE Tie rod boot replacement # 2835896? [Re: mopars4ever] #3100136
12/06/22 02:34 PM
12/06/22 02:34 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
While nothing like OE, Energy Suspension has some urethane tie rod boots for Mopar. I haven't used them yet, so can't comment on how they work.
1972 Dodge Challenger
Re: OE Tie rod boot replacement # 2835896? [Re: PLUM_72] #3100157
12/06/22 03:13 PM
12/06/22 03:13 PM
Georgia
69bfan Offline
69bfan  Offline
Georgia
The only factory appearing replacement boots to my knowledge are supplied through PG Classics or one of their vendors. Expect to pay around $155.00 for a complete kit as they do not sell the various boots individually.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: OE Tie rod boot replacement # 2835896? [Re: 69bfan] #3100187
12/06/22 05:33 PM
12/06/22 05:33 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What about some good originals ??
Re: OE Tie rod boot replacement # 2835896? [Re: Stanton] #3100212
12/06/22 07:52 PM
12/06/22 07:52 PM
md
md
Good original would be fine. Yeah, I seen the kit from Classics before. Kinda pricey. Also I see universal boots for sale on ebay. Has anyone tried them?
https://www.ebay.com/itm/265537758602
Re: OE Tie rod boot replacement # 2835896? [Re: mopars4ever] #3100218
12/06/22 08:15 PM
12/06/22 08:15 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Yes, and they are no better than any boot you can get at autozone or rockauto
Re: OE Tie rod boot replacement # 2835896? [Re: gtx6970] #3100220
12/06/22 08:20 PM
12/06/22 08:20 PM
md
md
As far as fit or rubber quality?
Re: OE Tie rod boot replacement # 2835896? [Re: mopars4ever] #3100226
12/06/22 08:48 PM
12/06/22 08:48 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Fit mostly and appearance is nothing like OE
Re: OE Tie rod boot replacement # 2835896? [Re: gtx6970] #3100310
12/07/22 02:43 AM
12/07/22 02:43 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
IIRC, true OE snap on boots require OE tie rods that are machined for that provision. Otherwise the don't fit right.
And someone that knows what and OE boot looks like, also knows how they are supposed to fit.
I thought MP sold an OE kit years ago. Very pricey at that time.
Re: OE Tie rod boot replacement # 2835896? [Re: autoxcuda] #3100321
12/07/22 07:49 AM
12/07/22 07:49 AM
Ohio
carteravs Offline
carteravs  Offline
Ohio
Re: MP boot kit. Yes, they did, and so did Mancini's.
Re: OE Tie rod boot replacement # 2835896? [Re: carteravs] #3100345
12/07/22 10:27 AM
12/07/22 10:27 AM
md
md
Yeah, they are OE tie rods.
Re: OE Tie rod boot replacement # 2835896? [Re: carteravs] #3100346
12/07/22 10:29 AM
12/07/22 10:29 AM
md
md
do you remember the Mopar part number for the kit? I found this. https://www.rosevillemoparts.com/product/boot-seal-package-a-b-c-e-bodies/
Re: OE Tie rod boot replacement # 2835896? [Re: mopars4ever] #3100355
12/07/22 11:14 AM
12/07/22 11:14 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
P5249225 62-67 A body
P5249226 68-76 A+ E body
P5249228 65-67 B body
P5249229 68-72 B body
P5249230 73-79 B body
Re: OE Tie rod boot replacement # 2835896? [Re: JohnRR] #3100357
12/07/22 11:22 AM
12/07/22 11:22 AM
md
md
Thanks John
Re: OE Tie rod boot replacement # 2835896? [Re: mopars4ever] #3100390
12/07/22 12:54 PM
12/07/22 12:54 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I think that “looks” like the old MP kits.
Don’t know about PG Classic rubber quality.
Their stuff typically is form over function. But really a case by case deal.
Re: OE Tie rod boot replacement # 2835896? [Re: autoxcuda] #3100395
12/07/22 01:00 PM
12/07/22 01:00 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Don’t forget break away OE zerks
