Indy hemi head 426 1RA #3100198
12/06/22 06:46 PM
12/06/22 06:46 PM
Canada
Cape Offline OP
Cape  Offline OP
Canada
Hey everyone. Thanks again for all the help on the oil pan thread.
I have a chance to buy an older set of Indy 426 1RA, they have a 2.380 valve and the 1.940, does anyone know if they will fit with a 4.280 bore? I have CP pistons that are 13.08:1 compression, they have an intake valve relief which at the widest part of it is 2.450 and tapers down to a 2.250 and no valve relief on the exhaust side. I also have no info on the pistons besides the brand and that there a 13:1 piston. Thanks.
Re: Indy hemi head 426 1RA [Re: Cape] #3100214
12/06/22 08:00 PM
12/06/22 08:00 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
You will probably have to notch the cylinder a little for the big intake valve but it's not hard. I can send you a link to the video if you need it.
2011 Drag Pak Challenger
Re: Indy hemi head 426 1RA [Re: rickseeman] #3100271
12/06/22 11:30 PM
12/06/22 11:30 PM
Canada
Cape Offline OP
Cape  Offline OP
Canada
Thanks for the reply, the block already has a little notch out of it right now, it’s a world block so they must have done it when the machining was done. Send the link please.
Re: Indy hemi head 426 1RA [Re: Cape] #3100274
12/06/22 11:39 PM
12/06/22 11:39 PM
I've rented and used the Isky tools for notching both pistons and cylinder wall bores wrench scope
Not real precise but I did get more than enough clearances with those tools and a good 1/2 drill motor wrench shruggy
I ended up buying all those tools I needed on the second engine that I needed them for up
Re: Indy hemi head 426 1RA [Re: Cape] #3100292
12/07/22 12:44 AM
12/07/22 12:44 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The part you want is near the end https://www.youtube.com/watch?v=Ewcj796lTKw
Re: Indy hemi head 426 1RA [Re: rickseeman] #3100304
12/07/22 01:39 AM
12/07/22 01:39 AM
Canada
Cape Offline OP
Cape  Offline OP
Canada
Thanks. I’ve been watching all your videos on building a hemi. Thanks for making them.
Re: Indy hemi head 426 1RA [Re: Cape] #3100410
12/07/22 01:35 PM
12/07/22 01:35 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
You're welcome and thanks for watching. I'm trying to show little things that others don't cover.
Re: Indy hemi head 426 1RA [Re: rickseeman] #3100501
12/07/22 07:30 PM
12/07/22 07:30 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Any links to the videos
1.39 9.85 - 137 mph
Re: Indy hemi head 426 1RA [Re: Ari440] #3100552
12/07/22 11:47 PM
12/07/22 11:47 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Re: Indy hemi head 426 1RA [Re: rickseeman] #3100783
12/09/22 12:29 AM
12/09/22 12:29 AM
Canada
Cape Offline OP
Cape  Offline OP
Canada
So it’s safe to say that anything under a 4.500 bore you won’t be able to use the 2.400 or the edelbrock 2.320 intake valve unless you notch the top of the cylinder? Has anyone tried the Indy 426 1RA with the 2.400 valve on any bore size under 4.500 to see if the work? Thanks for the help.
Re: Indy hemi head 426 1RA [Re: Cape] #3100828
12/09/22 10:50 AM
12/09/22 10:50 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Yes. I don't know what size you mean? 4.375? I don't know. I guess it would also depend on the head gasket thickness. It's easier to notch the block.
Re: Indy hemi head 426 1RA [Re: Cape] #3100917
12/09/22 03:15 PM
12/09/22 03:15 PM
What block are you using now?
Can you set a head on it with light checking valve springs to check the current clearances? If so do that next scope twocents
Re: Indy hemi head 426 1RA [Re: Cab_Burge] #3101008
12/10/22 12:24 AM
12/10/22 12:24 AM
Canada
Cape Offline OP
Cape  Offline OP
Canada
My bore is 4.280, it’s a world iron block, it is notched at the top already but not sure if it’s enough. I don’t have the Indy heads yet. I do have a buddy with the stage 5 millennium heads and those 2.400 intake valves hit either the block or the piston. I did try it with checker springs. The Indy heads I’m thinking of come with Norris rocker arms, how good are those rockers? Thanks
Re: Indy hemi head 426 1RA [Re: Cape] #3101020
12/10/22 04:46 AM
12/10/22 04:46 AM
The Norris exhaust rockers I used on a motor years ago were okay for a street and strip motor, way better than the stock ductile iron rockers twocents
Re: Indy hemi head 426 1RA [Re: Cape] #3101026
12/10/22 08:23 AM
12/10/22 08:23 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I do love the thought of Millennium heads but I think that's a bit much. Custom intake etc. (And then how big is your selection of intake manifolds?) The problem with using checker springs is yes, it cleared. But what if it's only by .001"? The checker springs won't tell you. Then what happens when it's running? Just notch the block to spec and quit thinking about it. It's fast, easy and if you want to go back to 2.25" intake valves it doesn't hurt anything. 59 years ago the Chrysler engineers gave you room to work with there for this very reason. That's why they gave you that recess in the head gasket. Give them the respect they deserve.
Re: Indy hemi head 426 1RA [Re: rickseeman] #3101078
12/10/22 01:43 PM
12/10/22 01:43 PM
Canada
Cape Offline OP
Cape  Offline OP
Canada
The millennium heads have an adapter plate that comes with them. My buddy was using an Indy tunnel ram intake for it and 1 1150 dominators. Apparently it was making 920hp from a 477 engine. Ya your right, just gotta get the heads to make sure it’ll clear, and if it doesn’t then so be it, notch it more. This might be a stupid question, would you take all the pistons out to do it? Or just mask it it up? Thanks.
Re: Indy hemi head 426 1RA [Re: Cape] #3101083
12/10/22 02:04 PM
12/10/22 02:04 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Of course the proper way would be to tear it down, but by turning the cylinders horizontal on the engine stand with careful masking you could probably do it. I would just tear it down because I'm not in a hurry.
