Re: 1969 d100 charging
[Re: twayne24365]
#3100208
12/06/22 07:33 PM
12/06/22 07:33 PM
Posts: 18,419 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
So if I put the new alternator in and run a wire from alternator too battery, I no longer need the factory voltage regulator, what about the wire going from voltage regulator to ignition? You can leave them alone or remove the regulator and tape the wires up into the harness.
