1969 d100 charging #3100141
12/06/22 02:46 PM
12/06/22 02:46 PM
Maryland
twayne24365 Offline OP
Maryland
I have a 69 d100 with a slant 6, it’s all factory with points ignition, what do I need to do to switch to a 1 wire internal regulated alternator?
Thanks!
Re: 1969 d100 charging [Re: twayne24365] #3100162
12/06/22 03:37 PM
12/06/22 03:37 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Nothing.
Re: 1969 d100 charging [Re: NITROUSN] #3100166
12/06/22 03:57 PM
12/06/22 03:57 PM
Maryland
Maryland
So if I put the new alternator in and run a wire from alternator too battery, I no longer need the factory voltage regulator, what about the wire going from voltage regulator to ignition?
Re: 1969 d100 charging [Re: twayne24365] #3100208
12/06/22 07:33 PM
12/06/22 07:33 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You can leave them alone or remove the regulator and tape the wires up into the harness.
Re: 1969 d100 charging [Re: NITROUSN] #3100247
12/06/22 10:14 PM
12/06/22 10:14 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Do make sure your 1 wire is self exciting as there were / are some that are not. wink beer
Re: 1969 d100 charging [Re: NITROUSN] #3100532
12/07/22 10:11 PM
12/07/22 10:11 PM
Maryland
Maryland
Thanks! I got it!
