Re: Cross Ram - inside work - dividers / block offs.....
[Re: patrick]
#310024
05/07/09 02:02 PM
05/07/09 02:02 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
expensive solution: multipoint EFI with twin TB's and the fuel rails/injectors internal to the cross ram. gets rid of a lot of wet-flow fuel distribution problems
there was a setup in a mag recently like that , multi point FI on a croaaram hemi , injectors and plumbing in the intake , to air horn throttle bodies on the top.
Larry , you have 1300 cfm on a 408ish inch engine ? I would think a smaller pair of carbs as a test would be the first test ?
[Re: JohnRR]
#310025
05/07/09 02:16 PM
05/07/09 02:16 PM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
I have a combined 780 cfm on my 360 and can idle at 700 rpm in drive - ( 2 holley 390's) but the tunnel ram dont have all those turns like a cross ram does, so fuel suspension is less of a problem for me
[Re: DJVCuda]
#310026
05/07/09 02:21 PM
05/07/09 02:21 PM
JohnRR
U.S.S.A.
Dave 780 on the tunnel ram is like having a thermobog on a dual plane on your 360.
[Re: JohnRR]
#310028
05/07/09 02:29 PM
05/07/09 02:29 PM
DJVCuda
Atco NJ
yup - only faster!
12.56 @ 106 compares to a stock ported iron intake and 780 cfm holley at 13.2 @102
[Re: LAR_414]
#310030
05/07/09 02:49 PM
05/07/09 02:49 PM
Posts: 4,573 ...gently down the stream
LAR_414
Wow that's some sweet work there on the EFI. That is sure nice. I'm sure it would be a challenge to get it inside this intake. Here's a pic, during mockup, before any damn's and such.
On the carbs, No sense trying smaller ones. It's not overcarbed. Even though theres not sure fire way to pick CFM for an engine, I'm in the ball park.
Remember, the carbs are rated at 1.5inches of vacuum. At WOT, you better not be pulling that kind of vacuum, or you have a major restriction. Assume your pulling 3/4 of an inch. A (rated 650 carb at 1.5 inches of vacuum), probably flows more like 450 cfm at 3/4 inch draw. Two of those is about 900cfm. My engine at 414 cubes and 6500rpm should need about 800 cfm at 100%VE. I'm Good!
[Re: LAR_414]
#310032
05/07/09 05:15 PM
05/07/09 05:15 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
I never tried one of those manifolds. The issue would be the vertical distance from the runners to the cover.
The biggest problem with the EFI conversion is the cost. Not only are the manifolds expensive but you have to commit to the entire EFI process. NOT for the weak of heart.
I don't have much input to your basic problem with the carbs. Sorry.
[Re: LAR_414]
#310033
05/07/09 08:23 PM
05/07/09 08:23 PM
Posts: 4,945 WI
Dcuda69
WI
Maybe a spread bore type carbs? I know it would be work to fit them on that intake(spacer/adapter?)Smaller primarys(better signal/velocity)but still the CFM you need at WOT.Just a thought? I've been watching this thread as I have the same problem(as I said in your Q&A post),great reading BTW!!Please let us know what you find as I'm sure there are other members who have the same issues with low speed drivability.
[Re: theclutcher]
#310034
05/07/09 08:45 PM
05/07/09 08:45 PM
Posts: 1,832 Fort Morgan
1OFNONE
Has been a member for quite a few years, so relax.
Fort Morgan
I spoke with Damon at Diamondback Engines in Texas who is the current foremost authority on these intakes. He told me to put a 1" 4 hole spacer under each carb. That made a huge difference. Next he said to put a 1/4 " spacer between the lid and the bottom to increase the radious the fuel has to turn in due to it just slams into the bottom of the plenium. I never did that cause the spacers cured my drivablity issues.
Call him and pick his brain. Very smart man.
Thats my 10 cents.
So the bartender says to the horse " Gee, Why the long face?"
[Re: LAR_414]
#310037
05/08/09 09:49 AM
05/08/09 09:49 AM
Posts: 2,172 Ohio
theclutcher
Ohio
The way this intake is designed, I'd have to separate the right and left cylinders, not the front and back ones.
Thats what I'd do, then adjust hgt. as needed, could almost do that on car.
After trying the 4 hole spacers...
[Re: theclutcher]
#310038
05/08/09 10:24 AM
05/08/09 10:24 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
This morning I did a dyno tune on a 68 hemi dart with the mopar cross ram. It was weird that this thing did not have the typical surging idle. When I went to pull the carbs to do some jetting bingo there was a 4 hole spacer. Maybe we are on to somthing. Jake
JAKES AUTOMOTIVE
