Re: Best head gasket for TF 270's ?
[Re: Blown 68 R/T]
#3099847
12/05/22 03:34 PM
12/05/22 03:34 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
My “go to” gasket bore diameter for stock 400/440 blocks is 4.410”.
However, I haven’t test fit one on a TF head myself....... although I have several customers with TF heads that have used them without issue.
[Re: fast68plymouth]
#3099870
12/05/22 04:28 PM
12/05/22 04:28 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
I have the Cometic 4.410's on mine . 0.030 over factory block , 0.055 over factory block and 0.030 World block .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Blown 68 R/T]
#3099892
12/05/22 05:51 PM
12/05/22 05:51 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
Is the block a stock Mopar or aftermarket block? Iron or aluminum?
[Re: Blown 68 R/T]
#3100024
12/06/22 05:19 AM
12/06/22 05:19 AM
tex013
Sydney,Australia
Tex have you ever checked to see if the gasket is hanging over in the chambers in certain area's? I did a quick visual and seemed ok .Never noticed any sign of burn on gaskets when i swapped the heads between the 3 different motors . Tex
[Re: mopar dave]
#3100404
12/07/22 01:21 PM
12/07/22 01:21 PM
Posts: 1,127 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I have been using the Fel Pro marine head gasket with my Victor E heads on a 400 block. Never an issue. FWIW, that's a 4.500" bore gasket, regardless of what the specs say.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
