8 3/4 rear vs trans brake ????
#3098967
12/02/22 03:40 PM
12/02/22 03:40 PM
Posts: 19,509 north of coder
moparx
the transmission i have ready to put in my charger has a reverse manual valve body, and also a trans brake. the car has the original 8 3/4 rear under it with 3.91 gears and the original drive shaft with the vibration ring at the front yoke. should i even consider hooking up the trans brake ? rear tire size has not been decided on yet, but something around a 12.50 x 29 is being considered. my gut feeling is not to use the brake until the rear and driveshaft have been upgraded. the converter is a 4200 stall unit, so it should work ok foot braking it ? what say the people that are way smarter than this old dummy ? TIA !
Re: 8 3/4 rear vs trans brake ????
[Re: slantzilla]
#3098991
12/02/22 04:37 PM
12/02/22 04:37 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
I have a brake in mine. Year ago I broke the ring gear at the hit footbraking it. Tore every tooth off. Installed new Moser center section with nodular case, billet adjusters. Raced it last year off the foot, no issues. Next offseason going to buy S60, then I will use the brake. Don’t dare right now, and am making couple engine upgrades this current offseason. Hoping to get one more season out of this new 3rd member off the foot. Kinda bass ackwards to what I should be doing..rear should have come first
[Re: topside]
#3099023
12/02/22 05:58 PM
12/02/22 05:58 PM
Posts: 4,693 Wichita
GY3
Wichita
Hahaha!
Transbrake in front of an 8 3/4..
Hahahahahaahah.
[Re: humpty]
#3099089
12/02/22 10:13 PM
12/02/22 10:13 PM
Posts: 8,172 Plymouth, MI
Blusmbl
Plymouth, MI
How much power?
Slicks are easier than radials but I broke *a lot* of stuff with a 4 speed in my 68 Charger. Multiple 8 3/4 centersections, axles, driveshaft… and it didn’t make much power.
A soft converter and slicks will help but it’s still asking for trouble.
My current C body is making 600-ish on nitrous, weighs 4300 and I’m footbraking it. I fully expect to break an 8 3/4 this coming season just because of the weight so I’m already saving for a 9” or Dana.
[Re: Cab_Burge]
#3099339
12/03/22 10:12 PM
12/03/22 10:12 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Transbrake vs 8-3/4….. transbrake wins every time.
[Re: moparx]
#3099395
12/04/22 08:28 AM
12/04/22 08:28 AM
Posts: 2,930 A shed in England
Tig
A shed in England
Here's what I've found over the years.
1: 8 & 3/4" rears break. 2: You can still bust a Dana with just a footbrake. 3: Softer "Pro Gears" will help. 4: Dana parts and rear ratios are getting harder to find. 5: 9" based rears built to your spec are available as a virtual bolt in.
You can see where I'm going with this. I have a similar list for 727's - TH400's.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: moparx]
#3099399
12/04/22 08:53 AM
12/04/22 08:53 AM
Posts: 3,214 Md.
carnut68
Md.
I friend of mine is running one in a Vega, yes a Vega granted it's not heavy, but he uses a T brake and it's a big tire car.mid 9's. He modified the housing with big bolts to support the bearing caps. Hundreds of passes. Gear change when needed.
America First!
[Re: StealthWedge67]
#3099430
12/04/22 11:04 AM
12/04/22 11:04 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Transbrake vs 8-3/4….. transbrake wins every time. The 8 3/4 may win a battle or two, but the trans brake will win the war! LOL
