Replacing 904
#3099361
12/04/22 12:14 AM
12/04/22 12:14 AM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
I want to replace a 904 with a 727 (small block) with TTI headers, will it fit without modifications other than the driveshaft? 340 in a 72 Cuda. TIA, Jon
11B40
Re: Replacing 904
[Re: JonC]
#3099384
12/04/22 03:11 AM
12/04/22 03:11 AM
Posts: 43,207 Bend,OR USA
Cab_Burge
Re: Replacing 904
[Re: IMGTX]
#3100831
12/09/22 11:03 AM
12/09/22 11:03 AM
Posts: 15,892 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Different car but I have a 727 and TTI headers on my '89 Diplomat AHB and no fitment problems. Car was originally an A999 trans.
Facts are stubborn things.
Re: Replacing 904
[Re: JonC]
#3100862
12/09/22 12:34 PM
12/09/22 12:34 PM
Posts: 4,425 Michigan
MarkZ
Worthy
Worthy
I want to replace a 904 with a 727 (small block) with TTI headers, will it fit without modifications other than the driveshaft? 340 in a 72 Cuda. You'll need a balanced flex plate, shorter drive shaft and 727 slip yoke. Trans should go right in without any tunnel or header modifications. B&M 10235 Assuming you don't have weights on the torque converter for the 727. The converter will not interchange between the two transmissions.
Re: Replacing 904
[Re: TJP]
#3100975
12/09/22 09:30 PM
12/09/22 09:30 PM
JonC
Millinocket, Maine
I do know about the power loss, but I can't seem to keep a 904 together. I have a SB 727, and know about the balance and such but just wanted to know if there would be a problem with the headers. I have been looking for a 998 or 999 non lockup, but they are pretty scarce.
11B40
Re: Replacing 904
[Re: JonC]
#3101180
12/10/22 11:12 PM
12/10/22 11:12 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
You know you can build a 904 to take some serious horsepower. I know a few of them running 10's and one is running in the mid 9's Just saying you can build what you have and keep all your other components the same. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Replacing 904
[Re: JonC]
#3101415
12/11/22 08:15 PM
12/11/22 08:15 PM
Posts: 9,846 MI, usa
dvw
MI, usa
I do know about the power loss, but I can't seem to keep a 904 together. I have a SB 727, and know about the balance and such but just wanted to know if there would be a problem with the headers. I have been looking for a 998 or 999 non lockup, but they are pretty scarce. What failure are you having? You shouldn't have an issue. Doug
Re: Replacing 904
[Re: dvw]
#3105718
12/26/22 03:18 PM
12/26/22 03:18 PM
JonC
Millinocket, Maine
I'm not sure yet, I was driving about 35 nice and easy, I felt what I thought was I drove over something hard and looked in the rear view mirror for something on the ground and turned around to find it. I didn't find anything but as I gave it some throttle very easy there was a very pronounced thunk thunk thunk. I would still move, so with just coasting and super light on the throttle to try and keep it moving it would thunk thunk thunk. Let up on throttle and coasts smooth, just touch throttle very slightly and thunk thunk thunk. At first I thought I had broken the snout off the Torque converter, pulled the transmission and torque converter looks fine. It was a slow thunk thunk thunk so I pulled the differential and it looks good. The driveshaft looks good and the u joints look good. Any suggestions.? Oh, and all the mounts look good. Some slight mods on the engine, just guessing 350-375 HP.
11B40
Re: Replacing 904
[Re: 5thAve]
#3105772
12/26/22 07:33 PM
12/26/22 07:33 PM
Posts: 2,248 ILLINOIS
volaredon
ILLINOIS
I prefer durability over speed so once a 904 dies I usually go 727 and never look back. Unless it's behind a 318. Change that to "EVEN IF" it's behind a 318!
