Re: WHAT ENGINE OPTION [Re: 2002bluert] #3099112
12/02/22 11:43 PM
12/02/22 11:43 PM
Rochester NY
Jer Offline
Jer  Offline
Rochester NY
Originally Posted by 2002bluert
Thanks for all the input, I don't plan on racing the car at the track and plan on driving the car lots in the summer on nice days. I enjoy going to a lot of out of town car meets and to local ones as well. Some meets can be a few hours away and i wont be trailering it. It is a pretty low option Challenger with a rebuilt factory 318 auto and 8 3/4rear end.
To me, this is an easy answer. A rebuilt 318 is pretty darn reliable. Repaint it, dress it up with the wheels of your choice, maybe add a dual exhaust for the rumble, and enjoy the heck out of it.
Re: WHAT ENGINE OPTION [Re: Jer] #3099117
12/03/22 12:11 AM
12/03/22 12:11 AM
Central US
grancuda Offline
grancuda  Offline
Central US
408 from Blueprint is a pretty nice little combo for a cruiser, way cheaper than than some new, over complicated fuel injected late model hemi & would make just as much power.
https://blueprintengines.com/produc...small-block-chrysler-longblock-bpc4082ct
1967 Barracuda Formula S 383
1967 Chevy C10 Short Stepper
1980 Macho Power Wagon LWB 318
2021 Toyota Supra
Re: WHAT ENGINE OPTION [Re: grancuda] #3099119
12/03/22 12:28 AM
12/03/22 12:28 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Long distance cruiser I'd go with a nice 340/360/408 and some sort of OD trans. Could even stroke the 318 with a 340 stroker crank and put some better heads on it too.
If you go with a 360 get a 5.9 Magnum engine block as they use a roller camshaft. Might as well take advantage of that if starting from scratch.
Re: WHAT ENGINE OPTION [Re: grancuda] #3099184
12/03/22 12:36 PM
12/03/22 12:36 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
X2 wink
Re: WHAT ENGINE OPTION [Re: TJP] #3099227
12/03/22 03:08 PM
12/03/22 03:08 PM
moparx Offline
moparx  Offline
X2 wink
pretty nice price as well, considering it's dyno'ed and comes with the paperwork.
375hp from that package would put a lot of 440's to shame.
beer
Re: WHAT ENGINE OPTION [Re: Jer] #3099244
12/03/22 04:20 PM
12/03/22 04:20 PM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
I agree with this answer. The simple and cheapest answer is to add a four barrel intake and carburetor if doesn't already have one. Some headers (worse case) and dual exhaust with lower gears if desired. If he has to have a 440 then look for a running motorhome engine swap on intake, HP Manifolds or headers, and be done. I would suggest a camshaft swap but, with I've seen lately he'll be taking a risk with an improperly machined camshaft itself or defective lifters. The other contender would be if he wanted to build the 440 is having a reputable machine shop or engine builder and accounting for any potential part delays.
Re: WHAT ENGINE OPTION [Re: OrangeProwler] #3099330
12/03/22 09:36 PM
12/03/22 09:36 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
K. I. S .S.
A computer that never existed can't strand you miles from home.
Given a choice alongside a roadside if I had to replace a fuel pump 2 bolts on the side of the block beats dropping a tank
.adding in a computer and a gazillion sensors to a car that never had them is asking for trouble.
I've seen some pretty ratty wiring jobs.
Re: WHAT ENGINE OPTION [Re: volaredon] #3099350
12/03/22 11:13 PM
12/03/22 11:13 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by volaredon
K. I. S .S.
Just a FEW examples I have many more. Many of t ehigh $$ cars i have seen fall way short in the wiring dept.
These examples made it all the way across the auction block to the new owners driveway. The 57 was a 200K build in 2008 with a BRAND NEW complete Corvette driveline straight from Chevrolet. Gorgeous build but they couldn't keep the electrical issues under control. whistling beer
Re: WHAT ENGINE OPTION [Re: TJP] #3099352
12/03/22 11:19 PM
12/03/22 11:19 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
A few AFTER examples wink beer
Re: WHAT ENGINE OPTION [Re: TJP] #3099456
12/04/22 12:24 PM
12/04/22 12:24 PM
moparx Offline
moparx  Offline
i see you have seen and evicted many of the same "gremlins" i have dealt with over the years. biggrin
beer
Re: WHAT ENGINE OPTION [Re: moparx] #3099634
12/04/22 09:33 PM
12/04/22 09:33 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by moparx
i see you have seen and evicted many of the same "gremlins" i have dealt with over the years. biggrin beer
Yes, it is a common area that is poorly done by most as they have no training in the area and most of the DIY kits Like PAINFUL do not address things like USING THE PROPER CRIMPERS and TERMINALS.
HMM Problem: I don't have the correct sized terminal frown SOLUTION: Strip extra insulation and fold wire multiple times as needed
OR,
Wire(s) are to big for terminal frown SOLUTION: Cut as many strands as needed until it fits. THE PRO's know to cut the same number of strands off each wire when shoving multiple wires in to a TOO small terminal LMAO beer
Re: WHAT ENGINE OPTION [Re: TJP] #3099956
12/05/22 09:55 PM
12/05/22 09:55 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
When did you guys get under the dash of my car and take the "before" pictures? shruggy whistling
