1.5 versus 1.6 Rockers #3099243
12/03/22 04:07 PM
12/03/22 04:07 PM
California
GTXMEX Offline OP
GTXMEX  Offline OP
California
I bought 1.5 rockers and am reconsidering seeing if I can return them for 1.6 . Using DynoSim6 to see the possible difference, with a 508", 10.5 to 1, 850 carb (I may go bigger later), these are the differences. Probably not worth the hassle and added cost of the return for a primarily street, occasional strip car?
Re: 1.5 versus 1.6 Rockers [Re: GTXMEX] #3099250
12/03/22 04:33 PM
12/03/22 04:33 PM
SoCal
Brian Hafliger Offline
SoCal
I always use higher ratio if starting with new setup...
Brian Hafliger
Re: 1.5 versus 1.6 Rockers [Re: Brian Hafliger] #3099257
12/03/22 04:56 PM
12/03/22 04:56 PM
California
GTXMEX Offline OP
GTXMEX  Offline OP
California
Thanks Brian!
Re: 1.5 versus 1.6 Rockers [Re: GTXMEX] #3099259
12/03/22 05:01 PM
12/03/22 05:01 PM
New York
polyspheric Offline
polyspheric  Offline
New York
If the cam is smaller than optimum, they (almost) always help.
If the cam is too big it gets worse.
Generally, on higher ratio intake rockers help, the exhaust doesn't need more lift (better: earlier opening).
Boffin Emeritus
Re: 1.5 versus 1.6 Rockers [Re: GTXMEX] #3099716
12/05/22 09:30 AM
12/05/22 09:30 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
It will change valve geometry some, moving the pushrod angle outbd possibly requiring some head clearance.
Re: 1.5 versus 1.6 Rockers [Re: GTXMEX] #3099721
12/05/22 09:54 AM
12/05/22 09:54 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I don't trust that series of simulation programs to give realistic results any longer... FWIW
Rocker ratio should be selected in conjunction with cam profiles, LSA, etc. That said, my personal experience has been anywhere from no improvements found to maybe 5-8 HP on "best case" scenario.
The other thing is you can't ASSume the published ratios reflect the actual delivered (real valve springs, not checking) ratio. It can also vary a good bit from above to below stated ratio depending upon brand / design. It's one of those areas that the only way to know is to mock up everything with the actual parts and check the net lift.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: 1.5 versus 1.6 Rockers [Re: Brad_Haak] #3099751
12/05/22 10:57 AM
12/05/22 10:57 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
this.
