Re: Anyone use lightweight batteries? [Re: Brad_Haak] #3099094
12/02/22 10:26 PM
12/02/22 10:26 PM
Anoka County, MN
Leigh Online content
Leigh  Online Content
Anoka County, MN
I need ballast, however, I appreciate new, viable technology.
Re: Anyone use lightweight batteries? [Re: Leigh] #3099133
12/03/22 03:39 AM
12/03/22 03:39 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Dynabatt fan here. I’ve only had it for a year, but sometimes it sits for a month at a time; lowest voltage has been 12.08. Crank it up and within 5 minutes it’s at 12.8. Price friendly too!
Re: Anyone use lightweight batteries? [Re: Brad_Haak] #3099143
12/03/22 08:29 AM
12/03/22 08:29 AM
Long Island, NY
ValiantRich Offline
ValiantRich  Offline
Long Island, NY
I have been using the Powerlite from Altronics for about 5 years with good results. I have no alternator and it charges up pretty quickly between rounds. Weighs 10 lbs. and it’s 16 volts cranks over my 16-1 small block just fine. Good way to save weight for me. Much better than the 16 volt Turbo Start that I used to use and had to be replaced every year and weighed almost 50 lbs.
Re: Anyone use lightweight batteries? [Re: ValiantRich] #3099146
12/03/22 09:18 AM
12/03/22 09:18 AM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
Just measured my Optima Red Top... 39.8 lbs. There's an easy 20+ lbs without even going to one of the super small options.
I like Andy's idea of the clamp-on ammeter to do spot-checks on charging characteristics.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Anyone use lightweight batteries? [Re: Leigh] #3099700
12/05/22 05:22 AM
12/05/22 05:22 AM
gregsdart Offline
gregsdart  Offline
Not sure if i agree about your needing ballast. I have a Dakota lithium 60 ah battery that weighs 16 lbs. It delivers the same reserve as a 100ah due to the difference in how the voltage stays up during discharge. It is also 60 amp alternater compatible. With that battery up front, you can dump the long cables to the trunk, saving another 10+ lbs. That would be a minimum reduction of 34 lbs in most cases, more in some. I haven't run it yet, but will in the spring.
Re: Anyone use lightweight batteries? [Re: gregsdart] #3099814
12/05/22 02:01 PM
12/05/22 02:01 PM
moparx Offline
moparx  Offline
as the inner fender below the battery box in my charger is slightly eaten up by acid leaking/gassing, i'm tempted to modify that area to mount a small, lightweight battery, and get rid of the factory mounting tray.
as already said, it would save a bunch of work by not moving the battery into the trunk.
however, what would one do for a cutoff switch at the rear ? a morse cable would work, but what size cable [not the outer sheath] would be appropriate ?
if there was enough room, could the cable possibly be routed along the interior sill plate and pass through the firewall to the front frame rail, and still operate smoothly ?
beer
Re: Anyone use lightweight batteries? [Re: moparx] #3099838
12/05/22 03:17 PM
12/05/22 03:17 PM
gregsdart Offline
gregsdart  Offline
beer
i have a rear cutoff using a morse cable to the switch up front. Nhra doesn't require a cutoff with a stock battery location up front. No sure on hood requirements
Re: Anyone use lightweight batteries? [Re: gregsdart] #3100115
12/06/22 01:39 PM
12/06/22 01:39 PM
moparx Offline
moparx  Offline
what size cable are you using Greg ?
beer
Re: Anyone use lightweight batteries? [Re: gregsdart] #3100203
12/06/22 07:02 PM
12/06/22 07:02 PM
cudadoug Offline
cudadoug  Offline
beer
Exactly what I did. I cut down a repop battery tray, leaving enough room for a cut off switch. Although not required, it is piece of mind to shut off the car's electrical system as needed. Bad pic, but I will post an updates pic later.
Re: Anyone use lightweight batteries? [Re: moparx] #3100209
12/06/22 07:35 PM
12/06/22 07:35 PM
gregsdart Offline
gregsdart  Offline
beer
Can't remember exactly, maybe 0? About 3/8 fine stranded welding cable. Since everything is up front, a size smaller is ok versus a rear mount cable.
Re: Anyone use lightweight batteries? [Re: cudadoug] #3100300
12/07/22 01:14 AM
12/07/22 01:14 AM
cudadoug Offline
cudadoug  Offline
Here are a couple of more pics. Please forgive the wiring mess; I’m changing a few things and haven’t wrapped it back up.
