383... who's stroker kits would you use? #3099000
12/02/22 05:04 PM
12/02/22 05:04 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
isee mancini uses eagle, there is molnar cranks and rods.. though i,m not sure they do a kit.., 440 source?..
just a street car like 450 cid or so out of my orig 383 block without a ton of grinding...like to hear any recommendations thanks guys,.,.
Re: 383... who's stroker kits would you use? [Re: ph23vo] #3099004
12/02/22 05:13 PM
12/02/22 05:13 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Lots of opinions on this, I used a 440 source for my 400 block set up 512ci, everything checked good out of the box, still pin fitted the piston pins to the pistons AND rods, crank was very good, been running it for lots of smiles.
Re: 383... who's stroker kits would you use? [Re: CSK] #3099018
12/02/22 05:51 PM
12/02/22 05:51 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
thanks all info appr
Re: 383... who's stroker kits would you use? [Re: ph23vo] #3099030
12/02/22 06:13 PM
12/02/22 06:13 PM
What amount of power and what size C.I. do you really want?
Re: 383... who's stroker kits would you use? [Re: Cab_Burge] #3099051
12/02/22 07:14 PM
12/02/22 07:14 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Unfortunately availability is a bigger problem now than quality. Check around for what is a actually in stock and your choices will probably be narrower.
Re: 383... who's stroker kits would you use? [Re: Cab_Burge] #3099053
12/02/22 07:19 PM
12/02/22 07:19 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I've been playing with different B block strokers for over 30 years. All things being considered, I'm a firm believer in Molnar crank & rods & then choose your piston of choice. Lots of companies make off the shelf pistons to make common combos, choose the brand you like best.
Re: 383... who's stroker kits would you use? [Re: ph23vo] #3099078
12/02/22 08:41 PM
12/02/22 08:41 PM
Idaho
boomerodell Offline
boomerodell  Offline
Idaho
We are planning to build a 496 with .060 over 383. The only kits I have found are Hughes and 440 source for my cid. I spoke with Glen @ Hughes earlier this summer about their kit and he mentioned that they were mix and matching crank and rod manufactures to complete the "kits". Molnar crank/Eagle rods etc if the customer didn't mind. Maybe by now they are getting some of that stuff back on the shelf. 440 source has a 438 kit, a little smaller than your goal but both their 438 and 489/496 they claim minimal grinding if any. Pretty sure the source kit uses Icon pistons like Hughes. I have a 500 inch 440 source kit in a RB with roughly 12,xxx miles and zero issues. I will probably use Todd Marsh when we are ready he can get Molnar and Diamond pistons to put something together for you. Of course if and when available.
Re: 383... who's stroker kits would you use? [Re: boomerodell] #3099085
12/02/22 09:52 PM
12/02/22 09:52 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
APPR THE INFO GUYS.. MORE THE MERRIER
Re: 383... who's stroker kits would you use? [Re: ph23vo] #3099240
12/03/22 04:02 PM
12/03/22 04:02 PM
SoCal
Brian Hafliger Offline
SoCal
440 source is just fine for your application.
Brian Hafliger
Re: 383... who's stroker kits would you use? [Re: ph23vo] #3099252
12/03/22 04:39 PM
12/03/22 04:39 PM
I've built several B and RB motors by using a stock forged steel 440 crank and have them offset ground down to BB Chevy rod size which can increase the strohe from 3.90 up to, depending on how good the crank is to start with on the rod journals indexing, to 3.910 not enough to worry over. To use them in a B block you need to have the main journals turn down also to the stock diameter wrench
I've had one done now for my next 383 build for my 1969 Dart GTS 383 4 speed car, I bought a set of the SpeedMaster( Chineze imports) BB Chevy type rod that iare7.100 center to center and I'm now waiting on having the block rough bore before ordering pistons and rings. This combination will make between 448 up to 451 C.I., depending on the bore size used work
I started using Ohio Crankshaft CO 4.25 stroke cranks a long time ago (circa 1995) with the BB Chevy rod journals sizes with the BB Chevy style long rods and had really good luck with those motors out running and lasting longer than those using the 4.150 stroke with the stock Mopar rod journals and heavier rods and pistons shruggy
I would not build a high HP 383 motor due to them having the thinner, weaker, main webbing in them like the stock OEM 440 motors have down whiney
All the stock 400 blocks are a lot better choice to use for a decent stroker build twocents wrench up scope
Re: 383... who's stroker kits would you use? [Re: Cab_Burge] #3099271
12/03/22 05:43 PM
12/03/22 05:43 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
THANKS CAB, ITS FOR MY 68 383 FORMULA S..SO I WANT TO KEEP THE ORIGINAL MOTOR IN THE CAR,, WILL BE USING ORIG EXH MANIFOLDS ALSO.. IT NEEDS A REBUILD
JUST FIGIRED I WOULD BUY A STROKER KIT AND MAKE IT A LITTLE FASTER AND HAVE ALL NEW PARTS.. JUST A STREET CAR 280-510 HYDRAULIC 3;23 REAR 340 CONVERTER
DON'T CARE WHERE THE HP ENDS UP.. SINCE I,M USING MANIFOLDS WOULD YOU REC MAYBE A 432 OVER A 472 OR 496?.. THANKS DAN
Re: 383... who's stroker kits would you use? [Re: ph23vo] #3099273
12/03/22 05:57 PM
12/03/22 05:57 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
If using ex manifolds, I recommend getting a custom cam, you will need one with 112 to 114 ish LSA for it to work better with manifolds
Re: 383... who's stroker kits would you use? [Re: CSK] #3099283
12/03/22 06:15 PM
12/03/22 06:15 PM
A727Tflite Offline
A727Tflite  Offline
Without sifting through past posts, has anyone compared power between a low deck motor versus a high deck with about the same displacement.
Re: 383... who's stroker kits would you use? [Re: CSK] #3099327
12/03/22 09:27 PM
12/03/22 09:27 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
the one i have is at 110.. 280 -510 mild one
Re: 383... who's stroker kits would you use? [Re: A727Tflite] #3099331
12/03/22 09:36 PM
12/03/22 09:36 PM
There is around 20 lbs. weight difference between a 400 and a 440 block of the same year scope
I can't remember making two stroker motors identical except for the blocks, B or RB stroker motors, pump gas or race gas confused
Re: 383... who's stroker kits would you use? [Re: ph23vo] #3099335
12/03/22 09:55 PM
12/03/22 09:55 PM
Idaho
boomerodell Offline
boomerodell  Offline
Idaho
Honestly if its the original block and you have no hp requirement just rebuild the engine. You didn't mention cylinder head or any other upgrade along with the cubic inches. Stock stroke 383's run really well.
Re: 383... who's stroker kits would you use? [Re: boomerodell] #3099424
12/04/22 10:42 AM
12/04/22 10:42 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
ITS BASICALLY THE SAME MONEY STROKED OR STOCK IS WHY.. PLUS MUCH BETTER PARTS TECHNOLOGY NOW... HAVE STOCK STEALTH HEADS , M/P STOCK STYLE ALUM INTAKE
AND ALUM W PUMP AND HOUSING TO DROP 100LBS OR SO OFF THE FRONTEND
Re: 383... who's stroker kits would you use? [Re: ph23vo] #3099557
12/04/22 04:59 PM
12/04/22 04:59 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
If you want to do something a little different, the stock crank with a 7.10 rod and the Icon IC-513 piston gives you a workable combination. Otherwise I would shop for crank and rods first, Icon has reasonably priced pistons for the 3.75, 4.15 and 4.25 combos with the 383 now. S/F.....Ken M
Re: 383... who's stroker kits would you use? [Re: EchoSixMike] #3099586
12/04/22 07:04 PM
12/04/22 07:04 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
SEEMS MOLNAR IS WHAT I AM HEARING A LOT FOR CRANK AND RODS.. WHAT DO YOU PREFER? THANKS FOR THE INPUT
Re: 383... who's stroker kits would you use? [Re: ph23vo] #3099644
12/04/22 09:53 PM
12/04/22 09:53 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
We have had a Molnar crank and rods since 2015. Beat the crap out of them! Great pieces!
'63 Dodge 330
11.19 @ 121 mph
