Page 3 of 3 1 2 3
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: hp383] #3097590
11/27/22 05:31 PM
11/27/22 05:31 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
Tractor trailer parts dealers.
1981 Dodge D150 360 auto
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: LarryJoew] #3097593
11/27/22 05:43 PM
11/27/22 05:43 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Certainly not cheap. But a very useful fastener.
If I really wanted to use Grade 8 type materials, I believe I would source the correct Gr8 Socket Head Flat Head Screws and fab the sleeve to the desire length. Wall thickness of the sleeve could be controlled for the desired strength.
4130 solid bar or thick wall tubing would be a good material. Can't imagine that the price per piece wouldn't be cheaper.
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: IMGTX] #3097656
11/27/22 10:46 PM
11/27/22 10:46 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by IMGTX
Originally Posted by moparjim79
Tell us what you're using them for
But please no pictures. I don't want to see what any one on here does with sex bolts.
Not to mention MATING SCREWS whistling stirthepot
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: TJP] #3097781
11/28/22 01:37 PM
11/28/22 01:37 PM
moparx Offline
moparx  Offline
FILM AT 11 !! panic up boogie penguin punkrocka .............. biggrin
beer
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: moparx] #3097860
11/28/22 05:31 PM
11/28/22 05:31 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
they have a lot of choices too
https://www.gardner-westcott.com/
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: bigdad] #3097946
11/28/22 10:28 PM
11/28/22 10:28 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Do be aware of any of the LBGT offerings, They've been know to break down prematurely whistling
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: hp383] #3098063
11/29/22 12:17 PM
11/29/22 12:17 PM
Alberta
rustbuckett68 Offline
Alberta
Here I was under the impression that in a shear type of mount, a grade 5 is better, as a grade 8 is too brittle. Grade 8s are more for clamping pressure than shear. I think most stock suspension bolts are grade 5, are they not?
Just stirring the pot. Were the old guys wrong in using a grade 5 in shear?l
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: rustbuckett68] #3098099
11/29/22 02:31 PM
11/29/22 02:31 PM
CA
crackedback Offline
crackedback  Offline
CA
smoke
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: rustbuckett68] #3098173
11/29/22 06:30 PM
11/29/22 06:30 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What I was told too, grade 5 for drive studs on axels more elastic, grade 8 has less shear strength, brittle. A guy had one of those tubular front ends with tubular lcas, while turning backing up slowly a 3/4” grade 8 bolt sheared off, car dropped to ground. Seams like a few had done the same so company made a double shear fix
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: crackedback] #3098230
11/29/22 10:59 PM
11/29/22 10:59 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by crackedback
smoke
haha
Should've added for protection after washer LMAO
Re: Where to find Grade 8 Sex Bolts, Mating Screws? [Re: cudaman1969] #3098231
11/29/22 11:02 PM
11/29/22 11:02 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
HMM never heard the above shruggy But with most uhh _____ coming from ______ a grade 8 could be a grade 2. I've seen some scary stuff from over there whistling beer
Page 3 of 3 1 2 3
