Radiator Electric Fan Set Ups, whatcha running? #3096290
11/22/22 12:24 PM
11/22/22 12:24 PM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
In process of putting drag car back on the track for next season. Will be running electric water pump, and have 26" 4 core radiator now to go in it. Curious what guys are running and recommended for electric fan on the radiator / shroud or not?
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: Mopar.70] #3096298
11/22/22 12:45 PM
11/22/22 12:45 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
What you have may work fine if you can keep the temp consistent....For the drags, not a lot of radiator & fan is required....Its the street that really tests a system....So for drag only, any universal 2 row 1" -1.25" tubes, typically a 31x19 will fit with a little work, and a set of cheap 12" dual electric fans....I ran that style setup for the last 20 years, until I put a Calais Hemi cast iron block in, and that damn thing is tough to cool on a 90* day....Switched to a 1.25" tube & spall 14" fans and a 50gph water pump...did the trick....
For me, I would find a wide tube universal rad that will fit, with a sheet metal shroud and 1-fan, and go with that...I like the Griffin ones best with the 1.25" tubes. Had Becool, and the Griffin way out does it. I had a shroud made for mine by Wizard cooling to gain the over sized fans, but for racing, one is all you need.
https://proshop.summitracing.com/parts/gri-1-56272-x
https://proshop.summitracing.com/parts/gri-cu-56272-x
New and then the old one....
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: Dragula] #3096301
11/22/22 12:58 PM
11/22/22 12:58 PM
PA
moparacer Offline
moparacer  Offline
PA
I have always had the best luck with SPAL. For track use only with an electric pump you could probably get away with just using a single 16 inch.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: Mopar.70] #3096302
11/22/22 01:02 PM
11/22/22 01:02 PM
an8sec70cuda Offline
Griffin radiator, direct bolt in replacement, but w/ 2 rows of 1.25" tubes. Meziere 42 gpm electric water pump.
Electric fan and shroud combo from a 2003 Dodge Viper.
It does pretty good, but tends to heat up on extended highway driving...65 mph at 3k rpm. Needs more water pump IMO.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: Dragula] #3096317
11/22/22 01:55 PM
11/22/22 01:55 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I had my aluminum rad custom made to still look somewhat Mopar style with two huge 1800 cfm Derale electric fans and -20 AN weld bungs. Keeps this car with more than double the horsepower of my other cars even cooler than they all run on the street.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: 6PKRTSE] #3096420
11/22/22 10:08 PM
11/22/22 10:08 PM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
All great info guys, thanks!
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: Mopar.70] #3096439
11/22/22 11:20 PM
11/22/22 11:20 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Big believer in Derale fans. US made, they move a lot of air, and they last.
Sales guy at Motorstate( Lane Automotive) went to a seminar at Derale few years back. When I went in looking for a good fan to replace the fan that came in my current car when I bought it, he was emphatic not to use anything else they stocked except Derale. They had Spal and many other brands to choose from..
Installed it, night and day difference, couldn’t be happier.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: B3422W5] #3096464
11/23/22 07:17 AM
11/23/22 07:17 AM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
I run a pair of Derale High Output fans for my Hemi and I have no cooling problems even with the AC running in the Florida heat. Quality fan and they flow a lot of air. I had Spal fans before. They were good as well, but the Derale fans cooled my application down better.
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: Mopar.70] #3096511
11/23/22 11:19 AM
11/23/22 11:19 AM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
I run a Taurus fan on a 26” aluminum radiator that’s under the trunk. It never gets over 180* the oem fans crush any aftermarket one. 90s Taurus fans are good, so are 98-02 camaro firebird fans.
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: 1980volare] #3096517
11/23/22 11:33 AM
11/23/22 11:33 AM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
iagree If you have the room for them. If you don't, then aftermarket is the only option. An OEM fan is not an option for a Hemi with serpentine belt accessory drive in an A-body, which was my case.
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: Mopar.70] #3096521
11/23/22 11:42 AM
11/23/22 11:42 AM
Lake Villa Il
INTMD8 Online content
INTMD8  Online Content
Lake Villa Il
I use Spal 30102130
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: INTMD8] #3096526
11/23/22 11:55 AM
11/23/22 11:55 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I use a $200 triple pass aluminum radiator and a $135 spal 16 inch radistor and it keeps my blown hemi around 185*
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: hemi-itis] #3096556
11/23/22 01:47 PM
11/23/22 01:47 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine runs a late model junkyard Dodge Charger dual fan set-up. Easy to fit. They move a ton of air.
Doug
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: dvw] #3096592
11/23/22 03:27 PM
11/23/22 03:27 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I use a Delta Pag 18" 4000CFM Brushless.
68 Barracuda Formula S 340
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: dvw] #3096593
11/23/22 03:38 PM
11/23/22 03:38 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
This is a good thread...
I'm considering installing one or two electric fans. I run lots of pylon autocross and HPDE/HSAX events... and after a while of long running time on the tracks, the temp rises... so I run with the heater on full-blast to help reduce some engine heat.
I have a recent new US Radiator Triple-Flow aluminum radiator, two 1.25" rows, 22" width (properly fitting my core support opening), factory fan shroud and 7-blade aluminum clutch fan, have tried different thermostats.. 160-180-195, etc... runs great while normal driving... but when racing, especially lengthy sessions, the temp rises and gets pretty hot... changed the cap to a 21#... temp still moves up to around 220+... only under lengthy racing conditions.
I also added a foam filler (2" round) between the upper radiator tank and the core support... so to prevent air from traveling away from the radiator.
So, I'm considering adding an electric fan... behind the radiator as I have a large automatic trans cooler in the front. I'm also planning to add an upper flat shroud from the grille-to-core support... as I see that many road racers have that added.
Since the radiator is only 22", I may add two electric fans and they would then likely over-extend the radiator width a little.. and that's OK with me. I would further have to remove the 7-blade clutch fan.
Comments, suggestions for electric fans on a 22" width radiator? My thoughts are that while idling after the runs (example: HOLLEY Bowling Green MOPARTY with lots of runs!), the electric fans would help much more, but... on hot lengthy HPDE lapping sessions, the temp has still run increasingly high during those typical 20-30-minute track sessions... really hot on warm summer days!
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: Mopar.70] #3096595
11/23/22 03:45 PM
11/23/22 03:45 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Twin spal pushers and an old Be Cool replacement rad, originally for a 528 motor. I guess it works OK on the 572, generally keeping the temp around 185 degree after a pass, back to the pits and pootling around on the street. I think it's marginal, I'm considering going to a dual or triple pass rad, I just don't have the room for big fans.
That having been said, last time out we had a faulty fan controller, I've just upgraded to another digital controller. It uses a screw in NPT temp sensor rather than a thermocouple that pushes into the rad fins. We'll have to wait a while see if it improves cooling though.
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: Mopar Mitch] #3096604
11/23/22 04:48 PM
11/23/22 04:48 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If you have a small block they are a little tougher to fit because the engine is longer than a BB from what I understand. I use an electric pump and the thinnest fan I could find and its a super tight fit. This is a 4000CFM Delta Pag fan and Meziere 35GPM pump with a speedway dual pass radiator.
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: Mopar.70] #3096624
11/23/22 07:07 PM
11/23/22 07:07 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Custom built B-Cool, 2 12” spal pullers. I just finished the 3/4” shroud. Have to wait till summer to see how it works.
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: rickraw] #3096778
11/24/22 11:32 AM
11/24/22 11:32 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Any concern with the lower rad hose not being near the bottom of the rad?
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: Bad340fish] #3096787
11/24/22 11:55 AM
11/24/22 11:55 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
No problems with it. Any lower the lower hose wouldn’t clear the oil pump. I would have to find some crazy curved hose to clear the oil pump, probably impossible.
