440 gas millage #3096063
11/21/22 03:10 PM
11/21/22 03:10 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Ok boys and girls what’s the best millage you’ve ever gotten out of a 440 past and present? AND how did you do it. I’m planning on using a 74 stock low compression one in my Lil Red truck. I’ll try to make a OD trans work too with the 3.55 rear
Re: 440 gas millage [Re: cudaman1969] #3096066
11/21/22 03:19 PM
11/21/22 03:19 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
14 mpg with my '71 Barracuda, 3.23 gears and Holley 750 vacuum secondary. 3.23 gears.
11 mpg with my '63 330. 505", 850 DP and 3.54 gears.
'63 Dodge 330
11.19 @ 121 mph
Re: 440 gas millage [Re: cudaman1969] #3096067
11/21/22 03:22 PM
11/21/22 03:22 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
I have never had a 440 that got more than 15 miles per gallon, but that is probably because I have a heavy right foot. whistling
My current 440, 500 hp and EFI, 4:10 5sp gets about 12 MPG around town driving with some highway thrown in.
My Monster are real!
Living within your means makes life pretty easy.
Re: 440 gas millage [Re: cudaman1969] #3096092
11/21/22 04:26 PM
11/21/22 04:26 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
I’m sure you know, the low compression is probably gonna cost you some.
Best I got was 18 or so, almost all highway. 1968 Charger, Holley 3310, A-833, 2.94 gears.
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: 440 gas millage [Re: metallicareload] #3096099
11/21/22 05:00 PM
11/21/22 05:00 PM
fredericksburg,va
fredericksburg,va
Back in1970 this dude that was hanging out at the car spots had a 69 Charger RT claimed he got 18-19 on highway. Claimed he worked for Chrysler and was some type of engineer from Detroit area. Never thought much about what he said until now. Gas millage didn’t mean much then when 260 was $.36 a gallon.
Re: 440 gas millage [Re: cudaman1969] #3096100
11/21/22 05:07 PM
11/21/22 05:07 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
On any of the 440 C bodies I owned . . . best was 15mpg on hiway. Pretty much all had 3:23, stock 70 440 . . .
Re: 440 gas millage [Re: cudaman1969] #3096108
11/21/22 05:45 PM
11/21/22 05:45 PM
Anchorage, Alaska
Anchorage, Alaska
I can believe it. On a long trip back in the day I got 20 or so one way and then 18 or so on the return
440, 4-Speed, 3.54
Re: 440 gas millage [Re: cudaman1969] #3096136
11/21/22 07:26 PM
11/21/22 07:26 PM
Midwest
MoparsnMissiles Offline
Midwest
Just as a point of reference, that $0.36 per gallon in 1970 is now the equivalent of $2.84 per gallon today.
So, not as much of a difference between then and now as you would first think.
Re: 440 gas millage [Re: MoparsnMissiles] #3096145
11/21/22 07:59 PM
11/21/22 07:59 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i'd have to say 10-14 depending on city or highway driving. 3.23 geared b-bodies with torqueflites. i don't believe any of the big numbers; engines are just too inefficient, and who's trying to correct those old speedometers where the factory had them running fast.
Re: 440 gas millage [Re: lewtot184] #3096151
11/21/22 08:17 PM
11/21/22 08:17 PM
Between Houston & Galveston TX
SattyNoCar Online work
SattyNoCar  Online Work
I've got a stock '77 440 in my wagon. When it was my daily, 12-14 (mostly city) was the norm. 14-15 was the norm strictly hwy but it did hit 16 a couple of times.
As I've mentioned numerous times, in a truck I used to have I swapped in a stock 440 to replace the truck's 360 and got better all around mileage. shock laugh2
John
Re: 440 gas millage [Re: SattyNoCar] #3096157
11/21/22 08:37 PM
11/21/22 08:37 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
It don't surprise me that much of anything could be at a 360 for mileage. Every one I've had has been a gas sucking pig.
Re: 440 gas millage [Re: cudaman1969] #3096175
11/21/22 09:54 PM
11/21/22 09:54 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
This is proof that there IS such thing as a dumb question.
Just kidding..........kind of.
Re: 440 gas millage [Re: Fat_Mike] #3096184
11/21/22 10:25 PM
11/21/22 10:25 PM
fredericksburg,va
fredericksburg,va
Ok. What’s the dumb part?
Re: 440 gas millage [Re: cudaman1969] #3096190
11/21/22 10:41 PM
11/21/22 10:41 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
It was many years ago and I was young, but my Father had a 440 powered C-body with a functioning lean burn system. I recall that he was very impressed with that big engine's economy in such a large car. I think he was getting 14 or 15 mpg with it. What ever the exact number was, it was several mpg better than any of his previous big blocks. I don't recall why, but he did not keep that car very long.
Re: 440 gas millage [Re: cudaman1969] #3096212
11/22/22 12:05 AM
11/22/22 12:05 AM
NW Illinois
MoonshineMattK Offline
NW Illinois
72 Charger, 72 New Yorker 440
CH4B intake, 600 Holley 1850
Electronic dist with vacuum advance
Stock untouched bottom end with windage tray. 2.14 /1.81 new valve job pocket ported. Hooker headers
Comp flat tappet with I think .450 Lift. Maybe could find the card
TKO 5spd with the .82 OD 2.76 rear gear
Could easily pull more overdrive gear. .82 was a mistake. Pulled the original 3.23 and installed the 2.76
Steady highway gets 18mpg
Re: 440 gas millage [Re: SattyNoCar] #3096240
11/22/22 08:06 AM
11/22/22 08:06 AM
Pa
K
koak Offline
koak  Offline
K
Pa
Stock '72 440, TQ, vac advance, 3.23's in a '70 E-body gave solid 16+ in mostly highway cruises keeping it under 70.
Re: 440 gas millage [Re: koak] #3096320
11/22/22 02:03 PM
11/22/22 02:03 PM
moparx Offline
moparx  Offline
i kind of figured the smiles per gallon were the measuring system for cost. biggrin
beer
Re: 440 gas millage [Re: cudaman1969] #3096346
11/22/22 03:41 PM
11/22/22 03:41 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
If mileage from a 440 is your primary concern, you will have to buy some KB quench pad pistons for open chamber heads, or build it to zero deck with some dish pistons to run withclose chamber heads.
There is some good info on the site about using the KB pistons and the resultant jump in gas mileage.
Re: 440 gas millage [Re: cudaman1969] #3096367
11/22/22 05:11 PM
11/22/22 05:11 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Not dumb, just my particular sense of humor relating to gas mileage and a 440 cubic inch motor.
Didn't intend to get you off topic...
Re: 440 gas millage [Re: Fat_Mike] #3096397
11/22/22 08:11 PM
11/22/22 08:11 PM
fredericksburg,va
fredericksburg,va
NO problem thought I was missing something, we good. For the post above what about the 70 6 pac piston with a 452 head vs the way down in cylinder 74 piston (8 to 1) I have the whole external balanced assembly I could use.
