12” ANCO Wipers
#3096109
11/21/22 05:48 PM
11/21/22 05:48 PM
Posts: 16,487 On the run…
BloFish
On the run…
These NOS wiper arms came with my A100 when I purchased it, although they have the correct arm angle to them, they are 12” blades as opposed to the factory 18” blades. They have been sitting in cold storage for the last 20 years and I have not ever seen another set, therefore I do not know what they are correct for. Anyone have any ideas?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
Re: 12” ANCO Wipers
[Re: BloFish]
#3096110
11/21/22 05:48 PM
11/21/22 05:48 PM
BloFish
On the run…
Re: 12” ANCO Wipers
[Re: A12]
#3096210
11/21/22 11:51 PM
11/21/22 11:51 PM
BloFish
On the run…
Thanks guys, I appreciate the help.
Re: 12” ANCO Wipers
[Re: Sniper]
#3096289
11/22/22 12:17 PM
11/22/22 12:17 PM
Posts: 21,523 N.E. OHIO, USA
A12
N.E. OHIO, USA
Good luck finding refills, I have those blades on my 51. I can't find refills for it though. NAPA's site list them as refill - YES but I couldn't find a listing for the refills. Call your local NAPA and ask if they have the 12" refills? https://www.napaonline.com/en/p/WIP61233dapters Required Yes Brand NAPA Blade Type Beam Adapters Included Yes Contents (1) Wiper Blade Blade Length 12 in Refillable YesManufacturer Part Number 61233 Sub Brand Classic VMRS Code 002035015
Re: 12” ANCO Wipers
[Re: Sniper]
#3096303
11/22/22 01:03 PM
11/22/22 01:03 PM
BloFish
On the run…
Good luck finding refills, I have those blades on my 51. I can't find refills for it though. I still have a new set in the package pictured if you need them.
Re: 12” ANCO Wipers
[Re: A12]
#3096411
11/22/22 09:22 PM
11/22/22 09:22 PM
Posts: 15,414 Omaha Ne
TJP
Omaha Ne
[quote=Sniper]Good luck finding refills, I have those blades on my 51. I can't find refills for it though. NAPA's site list them as refill - YES but I couldn't find a listing for the refills. Call your local NAPA and ask if they have the 12" refills? https://www.napaonline.com/en/p/WIP61233 51 what? have you checked with Bernbaum or Roberts?. Might also lokk at the older ford a chevy parts houses
Re: 12” ANCO Wipers
[Re: moparply]
#3096429
11/22/22 10:28 PM
11/22/22 10:28 PM
BloFish
On the run…
The A100 van takes the 18" blade assembly? 15 1/2 sorry.
Re: 12” ANCO Wipers
[Re: TJP]
#3096437
11/22/22 10:58 PM
11/22/22 10:58 PM
Posts: 6,282 nowhere
Sniper
nowhere
[quote=Sniper]Good luck finding refills, I have those blades on my 51. I can't find refills for it though. NAPA's site list them as refill - YES but I couldn't find a listing for the refills. Call your local NAPA and ask if they have the 12" refills? https://www.napaonline.com/en/p/WIP61233 51 what? have you checked with Bernbaum or Roberts?. Might also lokk at the older ford a chevy parts houses I have the ANCO 12" replacement blade assembly, the original blades used some real funky attachment, which I now find to be easier to get refills for, lol.
Re: 12” ANCO Wipers
[Re: Sniper]
#3096557
11/23/22 01:51 PM
11/23/22 01:51 PM
TJP
Omaha Ne
[quote=Sniper]Good luck finding refills, I have those blades on my 51. I can't find refills for it though. NAPA's site list them as refill - YES but I couldn't find a listing for the refills. Call your local NAPA and ask if they have the 12" refills? https://www.napaonline.com/en/p/WIP61233 51 what? have you checked with Bernbaum or Roberts?. Might also lokk at the older ford a chevy parts houses I have the ANCO 12" replacement blade assembly, the original blades used some real funky attachment, which I now find to be easier to get refills for, lol. that attachment method is identical to the wipers / arms on my 38 Ford
Re: 12” ANCO Wipers
[Re: TJP]
#3096858
11/24/22 04:13 PM
11/24/22 04:13 PM
Posts: 19,470 north of coder
moparx
i have taken the refills out of old blades and went to the parts store or wal-mart, and compared the rubber parts [blades] to modern vehicle availability. pretty lucky with finds, and most of the time, i can buy one refill, cut it in two, and fit it into the old refill metal retainer. your mileage will vary.
