COMPACT PRO STOCK #3095777
11/20/22 01:35 PM
11/20/22 01:35 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
I came across a Dodge Colt that's supposed to be a former P/S car. No lettering or any obvious markers as to who it belonged to. There seems to be many crashes with this body style, I think the latest was a few years ago CHGO?, Is there any strong info why they crashed(out of control) and what are the remedies? Hate to bring it back to life and meet the fate as others. Not going to be a show car. Probably a 9.0 or 8.50 car.
Re: COMPACT PRO STOCK [Re: A/MP] #3095814
11/20/22 03:38 PM
11/20/22 03:38 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Very short wheelbase
Re: COMPACT PRO STOCK [Re: GomangoCuda] #3095815
11/20/22 03:43 PM
11/20/22 03:43 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Too short for me. I don't have life insurance.
2011 Drag Pak Challenger
Re: COMPACT PRO STOCK [Re: A/MP] #3095816
11/20/22 03:45 PM
11/20/22 03:45 PM
moparx Offline
moparx  Offline
well, a short wheel base car with a TON of hp can be a handful.
add the wrong alignment specs to the front suspension, and "stuff" WILL happen.
this car only had a 440+6/727/dana 60 combo, and the below was the results.
in order to fit the engine, the struts were swapped side to side, which also dictated the rack to move to a front-steer position.
this caused two major factors to happen.
first, swapping the struts caused the caster to go WAY negative. think of an out of control shopping cart with wobbly front wheels.
second, the ackerman went way wrong, allowing the outside front wheel in a turn [correction maneuver] to sharply turn in a very decreasing radius than the inside wheel, thus resulting in a ton of tire scrub, similar to locking a tire on ice.
zero ackerman would have been better, but neither of the mentioned alignment items were tried to be corrected.
only the toe-in was set, but i forget what it was set to.
luckily, no one was hurt, but the car was a write off.
the drivetrain was later installed in a duster, and i "think" it goes [or went] mid to low 10's.
beer
Re: COMPACT PRO STOCK [Re: A/MP] #3095850
11/20/22 06:34 PM
11/20/22 06:34 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Isn't the Colt the same as the Plymouth Arrow which Bob Glidden successfully campaigned in Pro Stock? Ran 8.50's, won several events and set speed record several times.
Re: COMPACT PRO STOCK [Re: John_Kunkel] #3095883
11/20/22 09:40 PM
11/20/22 09:40 PM
Guitar Jones Offline
Similar but not the same, the Colt had a 90" wheelbase and the Arrow was 92". I am not certain but IIRC NHRA allowed them to stretch the wheelbase to 99". I think all the pro stock cars are 105" now.
Re: COMPACT PRO STOCK [Re: John_Kunkel] #3095886
11/20/22 09:43 PM
11/20/22 09:43 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I believe the Arrow had a slightly longer wheelbase, better aero, and a much lighter small block in the nose.
Colts with a Hemi were well known to be "twitchy".
Re: COMPACT PRO STOCK [Re: slantzilla] #3095917
11/20/22 11:34 PM
11/20/22 11:34 PM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
I can verify that the Colt can be a handful. I have been racing a '74 with BBM and about every 30 passes it reminds you who is the boss!
Re: COMPACT PRO STOCK [Re: A/MP] #3095936
11/21/22 09:32 AM
11/21/22 09:32 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
'My Colt is easy to drive but the fastest its been is 9.80s. I usually run 10.0 could go a bit quicker but no license.
Wheelbase is only 1" longer than a Pinto and 1" shorter than a Vega. I think a modern strut front suspension helps.
Re: COMPACT PRO STOCK [Re: RTSE4ME] #3096314
11/22/22 01:44 PM
11/22/22 01:44 PM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
I stretched mine to 105 inch and still run with a arms. Been as quick as 8.30's with 542 cid BBM
Re: COMPACT PRO STOCK [Re: mopacltd] #3096471
11/23/22 08:47 AM
11/23/22 08:47 AM
E
earlymopar Offline
earlymopar  Offline
E
Would sure like to see some pictures.
I stretched mine to 105 inch and still run with a arms. Been as quick as 8.30's with 5442 cid BBM
Re: COMPACT PRO STOCK [Re: earlymopar] #3096541
11/23/22 12:41 PM
11/23/22 12:41 PM
my own world
theraif Offline
theraif  Offline
my own world
i think a pinto a vega may be wider
Re: COMPACT PRO STOCK [Re: theraif] #3096583
11/23/22 02:57 PM
11/23/22 02:57 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW the heads up car we run is 96" wheelbase C3 Vette. It has been 1.08 60' 4.97 to the 1/8 and 171MPH in the 7.90's in the 1/4 so far and other than it being a totally stupid choice for a racecar it has not been an issue.
Re: COMPACT PRO STOCK [Re: mopacltd] #3096586
11/23/22 03:16 PM
11/23/22 03:16 PM
Lake Villa Il
INTMD8 Online content
INTMD8  Online Content
Lake Villa Il
Originally Posted by mopacltd
with 5442 cid BBM
What bore center is that? grin
Re: COMPACT PRO STOCK [Re: INTMD8] #3096601
11/23/22 04:11 PM
11/23/22 04:11 PM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
I can't seem to upload pictures to this sight. I was using a stock cast iron block.
Re: COMPACT PRO STOCK [Re: mopacltd] #3096630
11/23/22 07:29 PM
11/23/22 07:29 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I have some of mopacltd's colt
Re: COMPACT PRO STOCK [Re: RTSE4ME] #3096631
11/23/22 07:30 PM
11/23/22 07:30 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
nudder
Re: COMPACT PRO STOCK [Re: RTSE4ME] #3096813
11/24/22 01:03 PM
11/24/22 01:03 PM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
Thanks for posting pictures of my car. That dial was for S/ST 10.90 @155
Re: COMPACT PRO STOCK [Re: earlymopar] #3096888
11/24/22 06:01 PM
11/24/22 06:01 PM
moparx Offline
moparx  Offline
i showed what happens when the front suspension is not right ! eek
please make sure your front suspension is correct, and dialed in to make the car go straight !
beer
Re: COMPACT PRO STOCK [Re: theraif] #3096911
11/24/22 08:30 PM
11/24/22 08:30 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
I remember way back when, that I was talking to a road racer that was at the drag strip with friends. He was talking about poor handling with his Colt when he put a warmed SB in it. He talked about adding wider wheels and tires to keep it on all 4's. Maybe this is the problem or one of them.
