Anyone still use a "cool can" for fuel? #3095182
11/18/22 11:26 AM
11/18/22 11:26 AM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
I've never used one, but was wondering if people who have experience with them still think they're useful. Thx
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Anyone still use a "cool can" for fuel? [Re: Brad_Haak] #3095186
11/18/22 11:34 AM
11/18/22 11:34 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I asked this same question a couple years ago or so. I got answers all the way from "well top fuel cars are running 330 miles an hour in 3 seconds and they don't use a cool can" to "back in the day they would shave 3 seconds off of my ET but the NHRA banned them because they're a bomb looking for a place to explode!" grin
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Anyone still use a "cool can" for fuel? [Re: Hemi_Joel] #3095188
11/18/22 11:42 AM
11/18/22 11:42 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I briefly considered one...about 45 years ago...
Can't recall the last time I saw one.
There was an Engine Masters episode on fuel temp not too long ago - maybe look it up if you have the Motortrend+ streaming service ?
Re: Anyone still use a "cool can" for fuel? [Re: topside] #3095196
11/18/22 12:17 PM
11/18/22 12:17 PM
AndyF Offline
AndyF  Offline
I remember them from the 70's and 80's. The fast cars had those Moroso cool cans on them. Personally I don't think they do much if anything since colder fuel doesn't buy you much. Colder air buys you a lot but colder fuel is just slightly more dense which means that it might require a jet change but that doesn't really make more power. If you have a really hot engine compartment then it might help prevent fuel boiling. But once everyone switched to electric pumps the fuel boiling issue went away.
I'd say that if you have a modern bypass regulator fuel system with a return line then you don't need a cool can but you can plumb one in and try it if you want.
Re: Anyone still use a "cool can" for fuel? [Re: topside] #3095197
11/18/22 12:27 PM
11/18/22 12:27 PM
Loudoun County, VA
Loudoun County, VA
Just joined so I could watch that episode specifically.
EDIT: I can't say that their methodology reflects what you'd see at the track, but it certainly showed repeatable trends in lower fuel temp => higher output
Re: Anyone still use a "cool can" for fuel? [Re: AndyF] #3095199
11/18/22 12:32 PM
11/18/22 12:32 PM
Loudoun County, VA
Loudoun County, VA
It's still a dead-head system for now, but I recently picked up most of the parts to change to a return-line setup.
Re: Anyone still use a "cool can" for fuel? [Re: topside] #3095202
11/18/22 12:38 PM
11/18/22 12:38 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
I remember my dad and uncle used them on their cars WAY back in the day because most cars had steel fuel lines, a mechanical fuel pump and 94 octane pump gas, so they used cool cans to help stop vapor lock. As for today unless you're running an old school setup, most use return style regulators, so you wouldn't need a cool can because the fuel does not sit in the line and get hot vapor locking. Not sure if they still do or not, but I seem to remember seeing them on quite a few NHRA stock/super stock cars. However, if they still are using cool cans in those classes, its probably for contingency money. I've seen them on the cars, but never see the person putting ice in it between rounds.
Now for me, I did run a cool can on my '69 Z/28 "427" back in '84-'86 because when I moved to Arizona it was much HOTTER than Ohio, but I switched from using ice to using dry ice and alcohol. I can tell you that when I made the switch to dry ice it DID make a difference. Then I found a path to a new NOS Cheater nitrous plate system. LOL.
Wes
"Any fool can know. The point is to understand"
- A. Einstein
Re: Anyone still use a "cool can" for fuel? [Re: EvilB1Dart] #3095210
11/18/22 01:08 PM
11/18/22 01:08 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
my :two cents: is in an all-out performance situation they may have value, in a bracket car it’s just another variable to add into the mix
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Anyone still use a "cool can" for fuel? [Re: EvilB1Dart] #3095212
11/18/22 01:13 PM
11/18/22 01:13 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Wes
The ultimate cooling device! grin
'63 Dodge 330
11.19 @ 121 mph
Re: Anyone still use a "cool can" for fuel? [Re: W.I.N. Racing] #3095214
11/18/22 01:28 PM
11/18/22 01:28 PM
Loudoun County, VA
Loudoun County, VA
Originally Posted by W.I.N. Racing
..., in a bracket car it’s just another variable to add into the mix
Given my chasing my tail trying to be consistent w/ heat-soak issues and my 1320, that makes a lot of sense. Hot lapping w/ fuel temp variances just adds to the problem.
The fact that I just checked how much room there is in my 73's engine compartment to fit one, only to determine there isn't enough... just ended that idea anyway.
Re: Anyone still use a "cool can" for fuel? [Re: Brad_Haak] #3095228
11/18/22 02:13 PM
11/18/22 02:13 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
They make a great place for a can of Pepsi, especially if you pull it out in the staging lanes.
Re: Anyone still use a "cool can" for fuel? [Re: Brad_Haak] #3095243
11/18/22 02:37 PM
11/18/22 02:37 PM
Out of the State of Confusion
blue_stocker Offline
I used one in my stock eliminator car, but only at points meets and events...was worth .03-.05 sec depending on the temperature. The hotter it got (90-100*), the more it helped but like some have stated above, not in bracket racing. Class racing is a different situation and worth it. At certain events even using a towel packed with dry ice on the intake (prior to a run) is helpful, especially if it's heads-up. The Moroso unit in the next post is THE one to use, if you're going to run one as they are real nice and will probably yield more than my old school one in the picture.
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: Anyone still use a "cool can" for fuel? [Re: blue_stocker] #3095354
11/18/22 09:32 PM
11/18/22 09:32 PM
Dunnellon, FL
longram60 Offline
longram60  Offline
Dunnellon, FL
I just installed one in my stocker. It’s a Moroso unit, very nice, finned exchanger, well insulated with AN fittings. My intention is to use dry ice in alcohol. My thoughts are that it will help keep the fuel from vaporizing in the intake, displacing oxygen. My combo is carb restricted to begin with.
Unfortunately, the first test session last month was just after hurricane Ian. Apparently dry ice is a hot commodity during hurricanes. Will have to test with ice and water. Then the first qualifying run, my #7 rod decided to let go just before the traps, so I’m in rebuild mode and testing will resume next year.
1979 AMC Spirit, NHRA Q/SA
Re: Anyone still use a "cool can" for fuel? [Re: longram60] #3095386
11/18/22 11:11 PM
11/18/22 11:11 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I have this old one......
Re: Anyone still use a "cool can" for fuel? [Re: max_maniac] #3095472
11/19/22 12:13 PM
11/19/22 12:13 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The Eelco logo !
Re: Anyone still use a "cool can" for fuel? [Re: topside] #3095483
11/19/22 12:32 PM
11/19/22 12:32 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My buddy from high school has had one on his bracket car since the 80's. Not sure if it does a bit of good or not.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Anyone still use a "cool can" for fuel? [Re: longram60] #3095488
11/19/22 12:37 PM
11/19/22 12:37 PM
Loudoun County, VA
Loudoun County, VA
That's the one I was looking at, but there's no room for it under my hood, unless I was to route the fuel lines to the cool can over to the original battery location and back to the regulator.
