340 block code decifer
#3095166
11/18/22 09:53 AM
11/18/22 09:53 AM
Posts: 421 Australia
fullonmopar
Australia
Hi all, just picked up a 71, 340 block down under with eng number GW340P33750229 and a stamped number near the pan rail 1B240802. Definetly not an Australian delivered 340..Just curious about its history, any help appreciated. Picture is my Aussie factory 340 Charger.
Re: 340 block code decifer
[Re: Cab_Burge]
#3095237
11/18/22 02:27 PM
11/18/22 02:27 PM
Posts: 892 MA
steve70
MA
GW340P33750229
G=1971 Model year W=Windsor Ontario Assembly Plant 340=Cubic inches 3375=Saturday October 24th 1970 0229=229th engine assembled
1970 Challenger T/A 4 speed
[Re: steve70]
#3095410
11/19/22 02:19 AM
11/19/22 02:19 AM
fullonmopar
Australia
GW340P33750229
G=1971 Model year W=Windsor Ontario Assembly Plant 340=Cubic inches 3375=Saturday October 24th 1970 0229=229th engine assembled Thank you.
[Re: Cab_Burge]
#3095729
11/20/22 11:06 AM
11/20/22 11:06 AM
Posts: 2,534 God's Country Maryland
GODSCOUNTRY340
likely out of a demon or duster
3375 build date 10/24/1970 That would be a 1971 high compression Thermoquad motor, the fastest stock 340 motors made I think the '70 340 Six Pack engine might have something to say about that.
[Re: GODSCOUNTRY340]
#3095807
11/20/22 03:19 PM
11/20/22 03:19 PM
Posts: 43,292 Bend,OR USA
Cab_Burge
3375 build date 10/24/1970 That would be a 1971 high compression Thermoquad motor, the fastest stock 340 motors made I think the '70 340 Six Pack engine might have something to say about that. find one and try it and see I used to help Gene Buh l(SP?) run his NHRA stockers, the 340 6 pack Challenger was faster than his 1971 Demon 340 car, but NHRA put more HP on the 6 pack motor after he set the C/SA record with it I think they made his car have 5 more HP on that engine HP factor than the 1971 Thermoguard motor did, they didn't add the HP to the 1970 AAR Cuda, the T/A Challengers only He ended up quitting drag racing in the stock classes after that last factoring on him, he got into 4 wheel off roading and jeep trail rallies
[Re: mccannix]
#3095900
11/20/22 10:29 PM
11/20/22 10:29 PM
Cab_Burge
How many CFM does the stock 1968 340 Carter AVS flow? How about how many CFM on the 1971 Thermoquad? All the 1971 340 are rated by NHRA to be higher in HP than the 1968 to 1970 340 engines and the 1972/1973 340 motors for a reason, it ain't because of the camshafts
[Re: mccannix]
#3095943
11/21/22 09:59 AM
11/21/22 09:59 AM
GODSCOUNTRY340
I'm speaking from personal experience. Back in the mid 70's I had a '69 Swinger 340 car that I put a Holley 800 spread bore on and it ran the best of 13:22. Later I installed a six pack set up and the Dart instantly ran a best of 12:88 at 114 mph. The only thing done to the engine was a cheap 500 lift, 300 duration hyd. cam from JC Whitney and full length headers. I had a B&M 3500 Super Holeshot convertor and Zoom 513 gears.
