It depends what year it is. Older 413's have 2.00 intake and 1.50 exhaust valves. I believe when they went to the 516 head, the valves went to 2.08 intake and 1.60 exhaust. If it's a later truck/motorhome engine, it'll have 2.08/1.74 valves. Also if it's a '59-61 engine the crank is gonna have a funky 8 bolt flange that won't work with later transmissions and torque convertors.
Compression I'd guess is around 9.0 if it's from a car, more like 7.8 if it's from a motorhome. And B/RB camshafts are the same.
