Re: Dakota R/T Information
[Re: OrangeProwler]
#3094390
11/15/22 02:46 PM
11/15/22 02:46 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Fixing leaks and proper trans service including replacing filter and adjusting bands would almost bullet proof that trans in a stockish truck. Almost every time I have rebuilt one of those (100s of them) they had leaky tranny lines or cork pan gaskets that never got fixed and a lot of times people would come to me because another shop told them it needed a rebuild and I could fix it with simple band adjustments and fresh fluid and filter. Another common problem is the cooler had a checkvalve in it and they would get plugged, just cut that sucker out and bypass it.
[Re: poorboy]
#3094739
11/16/22 04:31 PM
11/16/22 04:31 PM
Posts: 20,185 Park Forest, IL
slantzilla
Park Forest, IL
I had an '00 R/T that I put 160,000 miles on in the 8 years I had it. I changed oil every 10K and serviced the trans every 30,000. Only trans issue I had was a broken clip that held the boost valve in.
Did the heater core at 160K. Water pump at 150K, A/C compressor at 170K. Other than that it was fairly bulletproof.
Daily drove it, pulled race car trailer, hauled tons of stuff in it, and drag raced it. 39K when I bought it, over 200K when I sold it still running strong.
[Re: OrangeProwler]
#3095240
11/18/22 02:34 PM
11/18/22 02:34 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
My 97 Dakota 2wd 5.2 RE44 with a good cooler and always use ATF-4 got 287000 miles out of the factory tranny. Changed fluid and filter around ever 30K. Even then the clutches and bands were not toast at the tear down. I of course never raced it but did tow with it. Towed several B bodies but never up any of our long 7% grades here.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#3095523
11/19/22 02:26 PM
11/19/22 02:26 PM
Posts: 1,819 Middle of A Field
OrangeProwler
Middle of A Field
My 97 Dakota 2wd 5.2 RE44 with a good cooler and always use ATF-4 got 287000 miles out of the factory tranny. Changed fluid and filter around ever 30K. Even then the clutches and bands were not toast at the tear down. I of course never raced it but did tow with it. Towed several B bodies but never up any of our long 7% grades here. That's great to hear. I have to wonder besides the check valve if lots of people used the incorrect fluid along with servicing the transmission caused a lot of failures compared to harsh use.
