Stronger stock 400 crank? #309399
05/05/09 11:29 PM
05/05/09 11:29 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
I've read now in a couple of books that the '72-'74 4bbl 400's had a cast crank that was stronger then the usual cast crank. Anyone else heard this, and how can these cranks be identified?
Thanks!
Re: Stronger stock 400 crank? [Re: polkat] #309400
05/06/09 12:48 AM
05/06/09 12:48 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Find one of the millions of 383's out there. Craigslist is a good place to look. And use the forged crank from it. You'll need a new balancer and torque converter, but if you're at the point where you're worried about the strength of a crank, Don't even mess around with a cast one!
Re: Stronger stock 400 crank? [Re: StealthWedge67] #309401
05/06/09 02:38 AM
05/06/09 02:38 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
No, I'm not worried about it, but I have a '73 4 bbl and was wondering if I had that crank?
Re: Stronger stock 400 crank? [Re: StealthWedge67] #309402
05/06/09 08:57 AM
05/06/09 08:57 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I agree with this , just get a 383 crank if you are worried about strength ..
stronger cast crank ??? I highly doubt that , where did you read this fairy tale ? fast68plymouth was making over 500hp in his 383 using a cast 400 crank , car ran low 11's ...
Re: Stronger stock 400 crank? [Re: JohnRR] #309403
05/06/09 02:25 PM
05/06/09 02:25 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Don Taylor's Big Block Mopar Engines makes this claim, and I've seen it elsewhere. Apparently it was a cast crank that was steel shotpeened. But I understand the logic of using a forged 383 crank.
