Intake water plumbing questions #309370
05/05/09 11:07 PM
05/05/09 11:07 PM
Edmonton, Alberta, Canada
Dartman75 Offline OP
I havn't yet removed the silly pies for the bypass hose and the return for the heater core. Those things are really difficult to remove from my old intake. They have slight slots in them, but I have no tools that will grab into them and turn. What is the secret to removing those things?
Is there anywhere to get them on the cheap in new condition if mine are too marked up or I mark them up further?
Greg
Re: Intake water plumbing questions [Re: Dartman75] #309371
05/05/09 11:08 PM
05/05/09 11:08 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Intake water plumbing questions [Re: mopars4ever] #309372
05/05/09 11:45 PM
05/05/09 11:45 PM
acetylene torch & I have not tried this but I plan to & that is to melt some candle wax into the threads
Re: Intake water plumbing questions [Re: RapidRobert] #309373
05/06/09 05:20 AM
05/06/09 05:20 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Let up know how that works!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Intake water plumbing questions [Re: Rug_Trucker] #309374
05/06/09 07:19 AM
05/06/09 07:19 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Heat like said above to get them broke loose.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Intake water plumbing questions [Re: Rug_Trucker] #309375
05/06/09 08:32 AM
05/06/09 08:32 AM
but Let up know how that works!
Rug you'll be the 1st to know. I will send you a PM
Re: Intake water plumbing questions [Re: MoparforLife] #309376
05/06/09 11:45 AM
05/06/09 11:45 AM
I assume heat on the intake and cool the pipe with an ice cube or something before attempting.
Shouldn't there be a socket like tool that fits those groves or something? If I reccall the last time I did this I was lucky enough to have some angle iron that fit the groves and strong enough to twist on. I don't scraps of metal like that where I'm at now but it might be worth my time to go find some as it comes in handy from time to time.
Do you think filing the groves open wide to accept a wrench handle or something with a bit more meat will be bad for it? Seems to seal on the flat of the pipe where the clamp will be and not the end anyways?
Re: Intake water plumbing questions [Re: Dartman75] #309377
05/06/09 12:08 PM
05/06/09 12:08 PM
Upper Midwest
Upper Midwest
called a pipe wrench
Re: Intake water plumbing questions [Re: Dartman75] #309378
05/06/09 12:14 PM
05/06/09 12:14 PM
that'll work but if it starts to distort I'd grab the torch as they get locked there pretty tight. the orig thin grooves are narrow as it doesn't take much torque to screw them in on the assembly line when they're new.
Re: Intake water plumbing questions [Re: RapidRobert] #309379
05/06/09 08:56 PM
05/06/09 08:56 PM
Rug_Trucker Offline
Rug_Trucker  Offline
Cool! I am wondering if it works on all kinds of studs etc.
Re: Intake water plumbing questions [Re: Rug_Trucker] #309380
05/06/09 09:11 PM
05/06/09 09:11 PM
I would be inclined to think yes and the guy who posted it sounded confident I just havent had the chance to try it yet. If it loosens them w less torch thats good.
Re: Intake water plumbing questions [Re: MoparforLife] #309381
05/06/09 10:00 PM
05/06/09 10:00 PM
St. Charles, MO
wingman Online happy
Uncreative Title
wingman  Online Happy
Uncreative Title
St. Charles, MO
By accident, I discovered that the blade of my gasket scraper tool fits in those slots perfectly!
I just put it in sideways (90 degrees to the fitting) and pulled on the screwdriver handle.
Pipe wrench probably still works best for getting them out, but I usually destroy them in the process.
So on my motor I bought new fittings, and installed them with teflon tape and the side of my gasket scraper. No leaks and no gouges from the pipe wrench!
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Intake water plumbing questions [Re: wingman] #309382
05/06/09 10:04 PM
05/06/09 10:04 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The idea is to heat them up and touch a candle to the outsides to get wax to melt into the threads. That does help to get them out. The wax penatrates better than most anything else and lubes also.
Re: Intake water plumbing questions [Re: stumpy] #309383
05/08/09 10:43 AM
05/08/09 10:43 AM
My solution was to pick up a piece of 1/8" flat iron that was about 1" wide and then cut it to 2" long. I used a 16 Oz precision insertion device and inserted it into the grove. Stuck a crescent on that and they turned out just fine. I had teflon'd them when I put them into the intake ~4 years ago so no heat required this time around. I used the same little flat iron to install them into the new intake, though the bypass nipple is hard to install with less than 180 degrees of turn that you can get on it. I cheated and stuffed a crescent in on the end of the flat iron pointing out from the nipple, then put a second crescent on the jaws of that guy so that I could turn it that exta 30 degrees to get a bite directly on the flat iron again. I'm contemplating next time just cutting a slot in a junk 1/2" socket with a cutoff wheel then welding the flat iron in place. A sufficiently big socket would wrap around the pipe or a sufficiently small socket would fit inside and not interfere and prevent the thing from slidding out of the slots and busting my knuckles so badly when it lets go from pushing at the wrong angles.
Once out, I cleaned them up and they looked great for having been through 3 previous intakes and 30 years of living in coolant.
Greg
