How high do you rev your 440s?
#3093022
11/10/22 01:54 AM
11/10/22 01:54 AM
Posts: 1,142 Loudoun County, VA
Brad_Haak
Loudoun County, VA
As in 3.75" stroke combos, not 4.15" +
My old build made peak HP at 6300-6400, I shifted at 6500 and went through the traps at 6800+
New combination makes peak HP at 6800 and I expect will go through the traps at 7000+... won't know where it'll want to be shifted until it sees the track again
Thx
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: How high do you rev your 440s?
[Re: Brad_Haak]
#3093036
11/10/22 03:59 AM
11/10/22 03:59 AM
Posts: 271 Anchorage, Alaska
metallicareload
Anchorage, Alaska
Man, good question. I'm trying to keep RPM down, because I got a stock crank with stock rods and swinging TRWs. But the higher I shift the faster it goes
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: Brad_Haak]
#3093038
11/10/22 05:03 AM
11/10/22 05:03 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Thx My guess is it will like 6800 shift points, because actual shift point (data logged) is most likely a couple hundred rpm higher than when you shift. So start at 6600 Imho and go up in steps, after getting a base line that is solid info to work from.
[Re: Brad_Haak]
#3093054
11/10/22 08:37 AM
11/10/22 08:37 AM
Posts: 1,774 Keymar, MD
DusterKid
Keymar, MD
Most of my 440 combo's which have been fairly mild (under 11:1, hydraulic flat tappet cams in the .530ish range and steel heads reworked) I always shifted at 6,000. My current engine is still mild by most standards, 10:9:1 with TF 240 heads and a .557 solid cam. If I'm running 1/8th mile I shift at 6,000, but if I run 1/4 mile I shift at 6500. Doesn't seem to make a difference, but with the gearing and tire size it seems to be more consistent in the 1/4 if I shift at 6500.
[Re: J_BODY]
#3093066
11/10/22 09:25 AM
11/10/22 09:25 AM
Brad_Haak
Loudoun County, VA
I don't have a data logger, but I'll have a playback tach for the first time ever
[Re: Brad_Haak]
#3093067
11/10/22 09:26 AM
11/10/22 09:26 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
My old stock stroke 440 w/ a pretty big roller and Indy SRs (unported) liked 6800. That was the combo that went 10.40s at 128-129 mph at 3700 lbs. My older mild 509 cammed iron head motor liked 6000-6200...11.40s at 117 mph in the same car.
Brad, I think you'll be in the 6800 ballpark.
[Re: lewtot184]
#3093082
11/10/22 10:15 AM
11/10/22 10:15 AM
Brad_Haak
Loudoun County, VA
I suppose I should mention the bottom end has an Eagle crank, Eagle rods, and Ross pistons
The only RPM-related concern might be the oiling system, but the upgrades done to it w/ the last build were targeted at better oil control at high(er) RPM
[Re: Brad_Haak]
#3093087
11/10/22 10:56 AM
11/10/22 10:56 AM
Posts: 570 UK
rb446
UK
In my opinion there's only 1 oiling system for 7k rpm and thats external, I know many have been ok with 1/2" internal and have lived but back in the day when I built my 440SP motor I looked at the oiling system and there was no question about it to me about not using it.
My motor ran to 6800rpm every run NA making just 515-ish fwhp with its stock bottom end and BV 906's and a .650" sft cam, 4.88's/32's, with N20 it trapped@7450, I only did that once!!, that motor is still running today albeit with a smaller cam. My mate with his 600hp 440 and 1/2" internal lasted 2 seasons@6800 and then threw 2 rods.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: rb446]
#3093090
11/10/22 11:03 AM
11/10/22 11:03 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
Hemi but almost stock 440 displacement. (3.75 stroke 4.31 bore). 7,600 so far.
Using Milodon 31580 oil pan and internal pickup.
[Re: J_BODY]
#3093092
11/10/22 11:05 AM
11/10/22 11:05 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Like Greg mentioned….. data recording can definitely make you adjust your shift light. It’s pretty interesting how much “time” can go by from: see shift light, arm moves shifter, trans makes mechanical shift My tach reads a little higher than my EFI does, it works out great, I pull the lever when I see 7000 and the actual shift takes place at 7000 +/- 50RPM or so.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3093095
11/10/22 11:19 AM
11/10/22 11:19 AM
Posts: 20,184 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Been a long time for me to have a stock stroke 440 but back in the late 1980’s I was shifting my Direct Connection copied build with the old .750 lift roller cams and was shifting from 6700-6900 rpm. Back then 9.80’s was pretty quick with the junk we had available
[Re: Brad_Haak]
#3093124
11/10/22 12:33 PM
11/10/22 12:33 PM
Brad_Haak
Loudoun County, VA
... My old build made peak HP at 6300-6400, I shifted at 6500 and went through the traps at 6800+
Checked my notes in The Wayback Machine and remembered I used to hit the 1-2 shift at 6200 and the 2-3 at 6500. Sounds comparable to new engine going 1-2 at 6500 and 2-3 at 7000.
