Crankshaft - What is it...? - SOLVED:Kellogg #3092574
11/08/22 02:04 PM
11/08/22 02:04 PM
Indy
AAR4Fun Offline OP
AAR4Fun  Offline OP
Indy
Rifling through some old boxes in the basement and came across a crankshaft I am not sure what it actually is. In a Direct Connection crankshaft box with no part numbers on the box. Found some numbers on the 1st counterweight.
1st photo - 1282
2nd photo - 10-22-81 285
It's an 8 bolt flange crank with a pilot bushing installed. Doesn't appear to have ever been drilled for balancing, probably new still.
Re: Crankshaft - What is it...? [Re: AAR4Fun] #3092593
11/08/22 03:21 PM
11/08/22 03:21 PM
God's Country Maryland
GODSCOUNTRY340 Offline
With that wide collar on the front it's a big block crank is about all I can tell you.
Re: Crankshaft - What is it...? [Re: AAR4Fun] #3092607
11/08/22 04:19 PM
11/08/22 04:19 PM
Indy
AAR4Fun Offline OP
AAR4Fun  Offline OP
Indy
Did some more research and found crankshafts in an old Direct Connection Catalog. One crankshaft available at that time carries the last 3 digits 285 in the catalog. Maybe that's what it is...
Re: Crankshaft - What is it...? [Re: AAR4Fun] #3092651
11/08/22 06:47 PM
11/08/22 06:47 PM
A727Tflite Offline
A727Tflite  Offline
Post a better pic of a main and rod journal showing if it has a full radius journal or undercut.
If full then AAR4Fun nailed it.
Re: Crankshaft - What is it...? [Re: A727Tflite] #3092767
11/09/22 09:18 AM
11/09/22 09:18 AM
Indy
AAR4Fun Offline OP
AAR4Fun  Offline OP
Indy
Both are Full Radius. Guess it's an old Kellogg crank.
Re: Crankshaft - What is it...? [Re: AAR4Fun] #3092770
11/09/22 09:26 AM
11/09/22 09:26 AM
A727Tflite Offline
A727Tflite  Offline
If I recall the only difference between the SS and ProStock cranks were runout, more select (less RO) for Pro.
They were great cranks.
