Heat treat or Cryo on tranny gears ? #3091387
11/03/22 12:46 PM
11/03/22 12:46 PM
Washington
hemienvy Online content OP
hemienvy  Online Content OP
Washington
I was considering heat treating some gears that I currently do not know the metallurgy of.
If a gear is already "heat treated", is there a penalty or benefit from heat treating again, just to be sure ?
Is there a benefit to Cryo treatment for tranny gears ?
Can you do both, Cryo and heat treat, in that order ?
Re: Heat treat or Cryo on tranny gears ? [Re: hemienvy] #3091475
11/03/22 07:22 PM
11/03/22 07:22 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I had the gears in my Richmond cryo treated with the face-plate mods and they are still on one piece. Liberty's done the work up It only took about 10 months luck
Gus beer
64 Plymouth Savoy
Dana 60
Re: Heat treat or Cryo on tranny gears ? [Re: hemienvy] #3091481
11/03/22 08:17 PM
11/03/22 08:17 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I'd look at cryo treating. There would be no benefit to heat treating the gears again. Plus you've no idea what the exact metal composition is, so the heat treatment company would not know the correct heat treatment procedure.
Alan Jones
Re: Heat treat or Cryo on tranny gears ? [Re: hemienvy] #3091490
11/03/22 09:08 PM
11/03/22 09:08 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
My suggestion is to do some research on both and see how they differ and what the effect is on the particular materials involved.
When I was looking into the effect of cryogenic-treating aluminum rocker arms, I found a couple of research papers on the subject to see how it changed the metallurgy, tensile strength, etc.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Heat treat or Cryo on tranny gears ? [Re: hemienvy] #3091508
11/03/22 10:19 PM
11/03/22 10:19 PM
I think all the Pro Gear ring and pinions are softer than stock OEM gears are so they will flex a little instead of cracking. work scope
I would do all the research I could before deciding either way work scopetwocents
Good luck up
Re: Heat treat or Cryo on tranny gears ? [Re: fourgearsavoy] #3091564
11/04/22 08:59 AM
11/04/22 08:59 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Add me to the Cryo treatment , I just had to buy a new cluster gear for a hemi 4 speed I had because 3rd gear was showing cracks , now I have a few others to have magnafluxed because I do not know the history of these trans' I have bought over the years .
Re: Heat treat or Cryo on tranny gears ? [Re: JohnRR] #3091572
11/04/22 09:58 AM
11/04/22 09:58 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Other than Liberty anyone got a recommendation for a firm to do this to transmission gearing?
Re: Heat treat or Cryo on tranny gears ? [Re: 6PakBee] #3091618
11/04/22 01:15 PM
11/04/22 01:15 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I cryoed a 727 output shaft before Rick Allison sold me an aftermarket one. My metallurgist said I wasted my money because of the material. I forget what the material is but once I told her she said cryo has no effect on that material type.
Re: Heat treat or Cryo on tranny gears ? [Re: markz528] #3091715
11/04/22 08:43 PM
11/04/22 08:43 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
What material? I didn't think cryo did anything to aluminum, but turned out I was wrong.
Re: Heat treat or Cryo on tranny gears ? [Re: Brad_Haak] #3091725
11/04/22 09:15 PM
11/04/22 09:15 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Has to do with carbon content. For life of me I can’t remember if the output shaft is high or low carbon content steel. Cryo works on one of them but has almost or no effect on the other.
Re: Heat treat or Cryo on tranny gears ? [Re: Brad_Haak] #3091730
11/04/22 09:19 PM
11/04/22 09:19 PM
LA360 Offline
LA360  Offline
An aftermarket output shaft would most likely be 300M, 4340 or something similar
Transmission gears will be 8620, EN36A, 9310 or something in that range. Something that is case hardened I would imagine, where as a shaft would be through hardened. I'll have to ask one of the material scientists at work about why cryogenic treatment might not work on some materials.
Alan Jones
Re: Heat treat or Cryo on tranny gears ? [Re: LA360] #3091748
11/04/22 10:49 PM
11/04/22 10:49 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Neither, get the parts WPC treated.
Re: Heat treat or Cryo on tranny gears ? [Re: Uberpube] #3091803
11/05/22 09:43 AM
11/05/22 09:43 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I looked on a few sites and WPC seems to be in the family of shot peening, a surface treatment. Heat treatment and cryogenic are internal treatments. I think they all have their place depending on what you are trying to achieve.
Re: Heat treat or Cryo on tranny gears ? [Re: 6PakBee] #3091955
11/06/22 09:54 AM
11/06/22 09:54 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Most production parts are already heat treated so the only thing you can really do to them is external treatments. The WPC process is a lot finer than than standard shotpeening.
A lot of the import cars never had aftermarket support for transmission parts or ring and pinions so it WPC became the trick to making stock parts live in performance applications. I use it a lot on my rotary engine builds.
Re: Heat treat or Cryo on tranny gears ? [Re: Uberpube] #3093128
11/10/22 12:40 PM
11/10/22 12:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Where do you get that done ?
The output shaft in the 4WD OD unit of the 47RE behind my 500HP Cummins was cryo treated because at the time billet wasn't readily available AND about 800bucks. I twisted off a factory piece power braking it against the convertor but I was too gunshy to try it again after fixing, but I never broke another with all the racing I was doing at the time.
Re: Heat treat or Cryo on tranny gears ? [Re: Uberpube] #3093254
11/10/22 08:59 PM
11/10/22 08:59 PM
Rittman Ohio
Rittman Ohio
I've been looking at some Youtube videos about this WPC coating and it looks like it has many applications in our drivetrains. I think oil pump rotors could really be a good application for this treatment. Transmission gears and rear gears would be a no brainer for this type of surface prep. I'm going to look into local outfits that may provide this service.
Thanks for the information up
Gus beer
64 Plymouth Savoy
Dana 60
Re: Heat treat or Cryo on tranny gears ? [Re: fourgearsavoy] #3093462
11/11/22 01:50 PM
11/11/22 01:50 PM
moparx Offline
moparx  Offline
if you go this rout Gus, please let us know how this works out.
beer
Re: Heat treat or Cryo on tranny gears ? [Re: fourgearsavoy] #3093463
11/11/22 01:50 PM
11/11/22 01:50 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Wpc is originally from Japan, but they have an office in California. I haven't used the California service, when I buy new Oem parts in Japan from a friend, he just gets the parts shipped directly to WPC from the OEM there and they process then ship to him.
I think if I change the flat tapped in my other 440 truck, I'm going to get the cam and lifters WPC'd along with the rest of the valvetrain. I've seen entire engines and transmissions that have been WPC'd.
Re: Heat treat or Cryo on tranny gears ? [Re: Uberpube] #3093471
11/11/22 02:06 PM
11/11/22 02:06 PM
moparx Offline
moparx  Offline
how far would the WPC coating go in preventing a solid flat tappet cam from loosing a lobe during break in ?
beer
