Stealth Head Push Rod location Out 1/8" #309121
05/05/09 09:18 PM
05/05/09 09:18 PM
Anonymous OP
Anonymous OP
hi guys,
Just called the engine shop to see how things are going together. It turns out that rocker arms are about an 1/8" off from where the push rod comes up. I called 440 source and they said it's not uncommon to have to clearance heads. But i'm not sure about taking an 1/8 off, Should i try another set of roller rockers??? the rockers are 1.7 ratio.
Not to sure on how to continue,or should i get them to grind the 1/8" per rod???
Thanks.
Re: Stealth Head Push Rod Our 1/8" #309122
05/05/09 09:45 PM
05/05/09 09:45 PM
Midland, Tx
rjones Offline
rjones  Offline
Midland, Tx
Had this same problem with 1.6 rockers on stealth heads. Pushrods that are too short will make problem worse. Solved by clearencing the heads and installing longer pushrods. Hope this helps.
Roger
Re: Stealth Head Push Rod Our 1/8" [Re: rjones] #309123
05/07/09 06:14 PM
05/07/09 06:14 PM
Anonymous OP
Anonymous OP
oh really, he noticed it when he went to check the push rod lenth needed to be ordered.
Any one else have this issue as well?
Re: Stealth Head Push Rod Our 1/8" #309124
05/07/09 06:29 PM
05/07/09 06:29 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
1.7 is far from stock. You might have to clearance any head for something like that.
Re: Stealth Head Push Rod location Out 1/8" #309125
05/07/09 06:33 PM
05/07/09 06:33 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Answer me this...
Aren’t the stock rockers 1.5 to one?
And you are at 1.7?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Stealth Head Push Rod location Out 1/8" [Re: HealthServices] #309126
05/07/09 06:37 PM
05/07/09 06:37 PM
So Cal
So Cal
A few companies sell 1.6 but not very many sell 1.7 Wonder why?
Re: Stealth Head Push Rod location Out 1/8" [Re: HealthServices] #309127
05/07/09 06:52 PM
05/07/09 06:52 PM
Anonymous OP
Anonymous OP
hi there,
here are the engine specs,
400 block bored .30 over
440 source 515ci blanced rotating stroker kit
Main studs, Gridle, windage tray, modified deep oil pan,
440 source Stealth Heads
Isky 292H Cam I belive is good for alittle over 500/500 lift,
I recieved these 1.7 rollers as a gift to help my engine build, I was told it would also help to raise the amount of lift.
I was thinking of just buying the whole 1.6 set-up from 440 source and see if that helps.
What do you guys recomend i do?
This is going to be for a race car as well.
Thank you for the help,
Re: Stealth Head Push Rod location Out 1/8" #309128
05/07/09 07:00 PM
05/07/09 07:00 PM
So Cal
So Cal
Your call but
This is from Hot Rodding
The rocker arm mechanically multiplies the cam's lobe lift. It does this by moving the pushrod closer to the fulcrum pivot point than the valve stem tip is. A simple example would be: if the valve tip centerline is located 0.750-inch away from the rocker fulcrum pivot centerline, then a 1.5:1 ratio rocker would have the pushrod cup located 0.500-inch from the pivot centerline (.750/1.5=.500). When you increase the ratio to 1.6, you obviously can't move the valve or rocker arm stud, you have to move the pushrod cup closer to the pivot centerline. So, now the math (.750/1.6=.470) tells us that the pushrod centerline is roughly 0.030-inch closer to the fulcrum pivot. This arrangement does more than just multiply cam lift. It also multiplies the loads on the pushrod, lifters, and rocker arms, making the proper ratio critical. Too much ratio will open the valves too quickly and can cause valve float at high rpm. It also multiplies the spring pressure seen on the cam lobes, so running too much ratio can wipe out a flat-tappet cam in no time. Thankfully the cam manufacturers have studied these problems and most won't even sell you too much ratio
If you want to use the 1.7 rockers you will need to grind it.
Re: Stealth Head Push Rod location Out 1/8" #309129
05/07/09 07:10 PM
05/07/09 07:10 PM
Anonymous OP
Anonymous OP
um, very informative...
So i'd bet at 1.5 ratio there would be no problem since it's at stock.
But when you .1 and up, it brings the center piviot closer causeing the need for clearancing.
interesting about spring pressures. I never even thought about that. um.
I would like power with longevity. so what do you guys think 1.5 or 1.6 ratio????
Re: Stealth Head Push Rod location Out 1/8" #309130
05/07/09 08:21 PM
05/07/09 08:21 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
I guess there are pluses to both but for a mostly street motor I would go with 1.5's and dial in the lift with the cam selection itself. Or maybe go with a roller?
Re: Stealth Head Push Rod location Out 1/8" #309131
05/07/09 10:54 PM
05/07/09 10:54 PM
Modesto CA
BFASTER Offline
BFASTER  Offline
Modesto CA
My pushrods were too short when I changed from the iron heads to the Stealth heads. I just had new pushrods custom made to fit for about $115 delivered to my door. A place in Southern California that my mechanic uses. Don't know the name but can get it easily.
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
