backing plate/spindle removal #309081
05/05/09 08:42 PM
05/05/09 08:42 PM
North Chicagoland
N
newbee69 Offline OP
newbee69  Offline OP
N
North Chicagoland
hey guys,
just started on a disc brake conversion on my 69 bee. Got the drums and shoes off pretty easily but am having a real hard time cracking the lower bolts that connect the spindle to the backing plate. Would taking heat to it be a bad idea due to it being so close to the ball joints and bushings? Kind of a dumb question but I figured Id ask before I did something that could do some damage.
Re: backing plate/spindle removal [Re: newbee69] #309082
05/05/09 08:55 PM
05/05/09 08:55 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
It will be easier to break the nuts loose on back first.
Re: backing plate/spindle removal [Re: buildanother] #309083
05/05/09 08:59 PM
05/05/09 08:59 PM
North Chicagoland
N
newbee69 Offline OP
newbee69  Offline OP
N
North Chicagoland
Thats what I meant....sorry.
Re: backing plate/spindle removal [Re: newbee69] #309084
05/05/09 09:06 PM
05/05/09 09:06 PM
New York
rarefish Offline
rarefish  Offline
New York
I'm assuming that you have removed the cotter pins from the lower two nuts, right? It is alright to put some heat on the nuts in the back then use an impact wrench on it. Just don't over do the heat.
Re: backing plate/spindle removal [Re: newbee69] #309085
05/05/09 09:13 PM
05/05/09 09:13 PM
chicagoland,usa
chicagoland,usa
You know, that Oz guy will chime in that this is what you penguins get for living in the rust belt...
Re: backing plate/spindle removal [Re: buildanother] #309086
05/05/09 09:47 PM
05/05/09 09:47 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I have always just been able to use the impact, and maybe a little penatrating oil if need be
Re: backing plate/spindle removal [Re: OzHemi] #309087
05/06/09 02:15 PM
05/06/09 02:15 PM
runningman Offline
super street
runningman  Offline
super street
I had a hard time getting mine out also, used an impact and penetrating oil. I ended up heating mine up a little after that didn't work and they finally broke free...
