What is the difference between a Dana 60 and Dana 60HD #309025
05/05/09 07:41 PM
05/05/09 07:41 PM
Colorado
hemi69cuda Offline OP
Colorado
I got a Dana 60HD housing what is the difference
between it and a Dana 60 case?
Re: What is the difference between a Dana 60 and Dana 60HD [Re: hemi69cuda] #309026
05/05/09 07:54 PM
05/05/09 07:54 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I believe it just has extra webbing on the case but I could be wrong LOL
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: What is the difference between a Dana 60 and Dana 60HD [Re: hemi69cuda] #309027
05/05/09 07:54 PM
05/05/09 07:54 PM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
I may be wrong on this, but I believe the HD has more stiffening ribs and mass. It's beefier. Dr. Diff would be the man to ask.
I'm Gumby dammit!
Re: What is the difference between a Dana 60 and Dana 60HD [Re: Gumbydammit] #309028
05/05/09 07:55 PM
05/05/09 07:55 PM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
Dang it ! I got tree'd!
I'm Gumby dammit!
Re: What is the difference between a Dana 60 and Dana 60HD [Re: Gumbydammit] #309029
05/05/09 07:56 PM
05/05/09 07:56 PM
Q
Quicktree Offline
Quicktree  Offline
Q
probably another 100#s
Re: What is the difference between a Dana 60 and Dana 60HD [Re: Quicktree] #309030
05/05/09 08:09 PM
05/05/09 08:09 PM
NC
HMcCandless_Jr Offline
NC
The HD has extra webbing plus it has thicker tubes. If you can use it do so.
Herb Jr
Re: What is the difference between a Dana 60 and Dana 60HD [Re: HMcCandless_Jr] #309031
05/06/09 08:42 AM
05/06/09 08:42 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Herb Jr
Re: What is the difference between a Dana 60 and Dana 60HD [Re: theclutcher] #309032
05/06/09 11:30 AM
05/06/09 11:30 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
I disagree. Why add weight when you don't have to since a Dana is already too heavy? Heavy HD housing with thick tubes are a total overkill for car applications especially when normal 60's with 1/4" or 5/16" wall tubes are still easy to find. Leave the heavy stuff for the rockcrawler guys.
Re: What is the difference between a Dana 60 and Dana 60HD [Re: 446acuda] #309033
05/06/09 01:10 PM
05/06/09 01:10 PM
Kissimmee Fl.
Kissimmee Fl.
my standard dana has 3/8 thick tubes in it and it is not a HD casting
Re: What is the difference between a Dana 60 and Dana 60HD [Re: dusturbd340W5] #309034
05/06/09 01:14 PM
05/06/09 01:14 PM
boscosis Offline
super street
boscosis  Offline
super street
The internals are the same. I suspect that it is a little heavier but have never compared them. As information we're running one in our Dart. Going from an 8.75 with a sure grip we gained 35# when we went to an HD-60 with a spool.
There is no way an HD housing is 100# heavier than a standard housing.
Re: What is the difference between a Dana 60 and Dana 60HD [Re: boscosis] #309035
05/06/09 01:35 PM
05/06/09 01:35 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
The difference may be 5-10 lbs.
Not worth fretting over for extra rigidity you get.
If you think 10 lbs is gonna make you set the national record thats another story.
Then you wouldnt want dana anyway.
