Re: Differential gasket for dana axle
[Re: moparjo68]
#3090139
10/29/22 09:31 AM
10/29/22 09:31 AM
Posts: 12,175 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Interesting question. Aren't those gaskets only like 3 or 4 dollars a piece? But the right RTV is a better choice.
Master, again and still
[Re: J_BODY]
#3090164
10/29/22 11:48 AM
10/29/22 11:48 AM
Posts: 487 Sonoran desert, Arizona, USA
moparjo68
I’m sure you’re aware those were sealed with RTV from the factory right? How would I know if its RTV sealed if i'd never taken one apart. They don't teach you anything useful like this in school.
[Re: moparjo68]
#3090187
10/29/22 12:44 PM
10/29/22 12:44 PM
Posts: 6,290 nowhere
Sniper
nowhere
I’m sure you’re aware those were sealed with RTV from the factory right? How would I know if its RTV sealed if i'd never taken one apart. They don't teach you anything useful like this in school. That is why you should have a FSM.
[Re: moparjo68]
#3090195
10/29/22 01:31 PM
10/29/22 01:31 PM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
I’m sure you’re aware those were sealed with RTV from the factory right? How would I know if its RTV sealed if i'd never taken one apart. They don't teach you anything useful like this in school. Well now you know! I prefer the Mopar gray for this task. Your rear is also coded “DSA”(noted from your build sheet post) limited slip, so be sure to add friction modifier when servicing.
[Re: J_BODY]
#3090246
10/29/22 04:21 PM
10/29/22 04:21 PM
Posts: 2,734 541 slobovia
A990
541 slobovia
I’m sure you’re aware those were sealed with RTV from the factory right? How would I know if its RTV sealed if i'd never taken one apart. They don't teach you anything useful like this in school. Well now you know! I prefer the Mopar gray for this task. Your rear is also coded “DSA”(noted from your build sheet post) limited slip, so be sure to add friction modifier when servicing. Be sure to check the gear lube bottle, when I put a tru-trac in my 9.25, I was surprised at how many brands have friction modifier already added.
[Re: moparjo68]
#3090280
10/29/22 06:35 PM
10/29/22 06:35 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
The 2 really good gaskets I have used are the Superformance and the Lube-Locker. Both gaskets are non wicking and they don't leak. Used Superformance on my own re-builds and my Savoy for about 3 years now with zero leaks. I used a Lube-Locker on my buddies drag car and it also works nice too. I hate cleaning sealer from surfaces when I can get a nice clean release from a good gasket Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: moparjo68]
#3090347
10/29/22 10:17 PM
10/29/22 10:17 PM
fourgearsavoy
Rittman Ohio
[quote=moparjo68]I like what Im reading about LubeLocker gaskets. I notice its offered for the Dana 60. Will the Dana 60 also fit the Dana 70 as the picture looks identical to what I need? [/quote They are listed as the same gasket and I have some gasket packages marked 60-70 use. I have a cast Ultimate 60 cover and I suggest a cast cover when using a gasket. Sometimes sealer will work better with a stock type steel cover though. I have used the Lube Locker with a stamped cover though and I think it's still sealed I haven't heard any complaints from the owner of the car. Gus
[Re: moparjo68]
#3090440
10/30/22 11:45 AM
10/30/22 11:45 AM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
I used the premium NAPA gasket with cork/rubber composite & thin steel in the center. And Permatex black goop. Never leaked a drop.
[Re: moparjo68]
#3090789
10/31/22 05:55 PM
10/31/22 05:55 PM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
25 years ago when I was working at the IH dealer, Dana was subbing RTV for paper gaskets.
1981 Dodge D150 360 auto
