Re: A-body Plymouth front fender splash shield question
[Re: WINGNUT]
#3089859
10/28/22 10:53 AM
10/28/22 10:53 AM
Posts: 43,592 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
73-76 are plastic, 72 down are metal. They should be interchangeable but I have never used the plastic ones...
JB Rhinehart, Realist
A-Body's RULE!
[Re: autoxcuda]
#3090266
10/29/22 06:00 PM
10/29/22 06:00 PM
Posts: 771 BRIDGEWATER, CT.
WINGNUT
BRIDGEWATER, CT.
67-69 Barracuda have a different profile and they are metal Thanks for the input. I'm trying to find out Duster specifically. WINGNUT
[Re: WINGNUT]
#3090277
10/29/22 06:28 PM
10/29/22 06:28 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
67-69 Barracuda have a different profile and they are metal Thanks for the input. I'm trying to find out Duster specifically. WINGNUT Just an FYI for caution Also… I believe the rear splash shield between the wheel well and front door jam area is the same as the corresponding year 67-72 and 73-76 Darts. The fender side profile is the same as they share the same doors: Dart, Valiant, Scamp…. Rhinodart can you deny or confirm this?
[Re: autoxcuda]
#3090282
10/29/22 06:49 PM
10/29/22 06:49 PM
Rhinodart
Rhinotruck
Rhinotruck
67-69 Barracuda have a different profile and they are metal Thanks for the input. I'm trying to find out Duster specifically. WINGNUT Just an FYI for caution Also… I believe the rear splash shield between the wheel well and front door jam area is the same as the corresponding year 67-72 and 73-76 Darts. The fender side profile is the same as they share the same doors: Dart, Valiant, Scamp…. Rhinodart can you deny or confirm this? Yes except the Valiant/Duster fender bends sharply down while the dart sweeps back at an angle so the splash shields are different, Plymouth has an extra bracket welded on also...
A-Body's RULE!
[Re: Rhinodart]
#3090336
10/29/22 10:00 PM
10/29/22 10:00 PM
autoxcuda
So Cal
67-69 Barracuda have a different profile and they are metal Thanks for the input. I'm trying to find out Duster specifically. WINGNUT Just an FYI for caution Also… I believe the rear splash shield between the wheel well and front door jam area is the same as the corresponding year 67-72 and 73-76 Darts. The fender side profile is the same as they share the same doors: Dart, Valiant, Scamp…. Rhinodart can you deny or confirm this? Yes except the Valiant/Duster fender bends sharply down while the dart sweeps back at an angle so the splash shields are different, Plymouth has an extra bracket welded on also... Thank you for clarifying. That makes sense about the wheel lip shape and how it ties into the splash shield. So 67-72 Valiant, Duster, Scamp: same metal rear splash shield ? And 73-76 Valiant, Duster, Scamp: same plastic rear splash shield ?
