Page 1 of 4 1 2 3 4
563 Dyno results #3089711
10/27/22 06:54 PM
10/27/22 06:54 PM
MN
JERICOGTX Offline OP
MN
Finally after a lot of headaches, I was able to dyno my 563 today. Very happy with the results, and I have to thank Thumper, for building one heck of a carb, and nailing the setup from the start.
Here is a run down of the combo:
INDY RB aluminum block
Molnar 4.375” crank
Molnar 7.100 rods
Diamond 4.524 bore pistons
13.4:1 compression
INDY 440-1 345CNC heads, prepped by Dwayne Porter
INDY 440-3X intake
Erson roller cam 288/302 duration
2.125-2.250 headers w/4” collector
Jesel belt drive
Milodon oiling system
MSD distributor w/ crank trigger
We made 9 pulls total. Mainly wanted to get the timing right, and carb setup right. Didn’t test any magical part of the month stuff.
Attached is the final pull we made.
69 GTX 68 Road Runner
Re: 563 Dyno results [Re: JERICOGTX] #3089713
10/27/22 06:58 PM
10/27/22 06:58 PM
tboomer Offline
tboomer  Offline
Way to go Jeff! Great results after the trying times you had! A nice picture of the happy daddy! wave
Re: 563 Dyno results [Re: JERICOGTX] #3089716
10/27/22 07:01 PM
10/27/22 07:01 PM
New York, USA
Chargerfan68 Offline
New York, USA
Congratulations on a nice combination and looks like a healthy motor. What lifters did you go with? Was that the peak hp or did it keep climbing?
Re: 563 Dyno results [Re: Chargerfan68] #3089717
10/27/22 07:04 PM
10/27/22 07:04 PM
MN
MN
They are Comp lifters. Board member/ friend R3 Racing aka Ron, gave me a too good to pass up deal on a extra set he had, that were just rebuilt.
Re: 563 Dyno results [Re: JERICOGTX] #3089721
10/27/22 07:34 PM
10/27/22 07:34 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
That smiles says it all..........
Nice job and congrats, Jeff! Man, I know it feels good to shake all the adversity thrown your way throughout the process, but it all worked out. Plenty of power and grunt for sure! It has some more in it! Can't wait to hear the track videos when the hammer drops and gears are being rowed.
What fuel was being used?
Wes
"Any fool can know. The point is to understand"
- A. Einstein
Re: 563 Dyno results [Re: JERICOGTX] #3089722
10/27/22 08:04 PM
10/27/22 08:04 PM
I like your pipes, up
What car, chassis, is it going in?
Re: 563 Dyno results [Re: JERICOGTX] #3089723
10/27/22 08:07 PM
10/27/22 08:07 PM
AndyF Offline
AndyF  Offline
Good numbers for passenger car headers with all the tight bends. A carb spacer would probably add another 10 or 15 hp if you have room under the hood.
Re: 563 Dyno results [Re: AndyF] #3089726
10/27/22 08:19 PM
10/27/22 08:19 PM
MN
MN
The engine is going into my ‘68 Road Runner. Car is a back half 4 link. With this engine and trans combo, it should weigh right around 3050lbs, with me in the car. Car is equipped with a Liberty Clutchless 4 speed, and Soft Lok clutch worked over by Black Magic.
Re: 563 Dyno results [Re: JERICOGTX] #3089727
10/27/22 08:21 PM
10/27/22 08:21 PM
MN
MN
Wes, all pulls were made with Sunoco 112 gas.
Re: 563 Dyno results [Re: JERICOGTX] #3089728
10/27/22 08:25 PM
10/27/22 08:25 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
8.80’s-8.90’s?
Sounds like a really nice combo!
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 563 Dyno results [Re: AndyF] #3089729
10/27/22 08:26 PM
10/27/22 08:26 PM
MN
MN
Most likely would have made more power, but didn’t see any reason to try anything that wouldn’t fit in the car. Dyno operator asked, and I just told him I wanted to optimize what I had, and wasn’t looking for a hero dyno sheet. I’m more that happy with the results, and at the end of the day, I just want to go racing again, and hang out with my friends. I’ll adjust the shoe polish on the window accordingly.
Re: 563 Dyno results [Re: B3422W5] #3089730
10/27/22 08:28 PM
10/27/22 08:28 PM
MN
MN
Originally Posted by B3422W5
8.80’s-8.90’s?
On a perfect day, you wouldn’t be able to wipe the smile off my face, if I was handed a time slip like that.
Re: 563 Dyno results [Re: JERICOGTX] #3089732
10/27/22 08:35 PM
10/27/22 08:35 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Outstanding!!!
With the weather we're having you might be able to get it in the car and make passes before the snow flies!
Re: 563 Dyno results [Re: Blusmbl] #3089744
10/27/22 08:58 PM
10/27/22 08:58 PM
MN
MN
Originally Posted by Blusmbl
Outstanding!!!
I’ll wait for spring. No tracks open around here anymore.
Re: 563 Dyno results [Re: JERICOGTX] #3089745
10/27/22 09:00 PM
10/27/22 09:00 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Great numbers. What timing did it like best?
Doug
Re: 563 Dyno results [Re: dvw] #3089747
10/27/22 09:06 PM
10/27/22 09:06 PM
MN
MN
Doug
It liked 34 1/2* the best. It fell off some at 35*.
Re: 563 Dyno results [Re: JERICOGTX] #3089764
10/27/22 10:09 PM
10/27/22 10:09 PM
AndyF Offline
AndyF  Offline
Looks like you have room for a carb spacer. A Wilson four to one combo spacer will add power on the 3X. Could be 10 to 15 on that engine.
Re: 563 Dyno results [Re: JERICOGTX] #3089798
10/28/22 05:53 AM
10/28/22 05:53 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
You get drool + drool from me, one for the engine and one for the Road Runner it's going in
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: 563 Dyno results [Re: Brad_Haak] #3089799
10/28/22 05:58 AM
10/28/22 05:58 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Very nice numbers Jeff! Can't wait to see you rowin' gears with it.
Re: 563 Dyno results [Re: quickd100] #3089802
10/28/22 07:02 AM
10/28/22 07:02 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Great Average hp number! Remember its more AVERAGE HP that moves the car quicker, not peak.
Page 1 of 4 1 2 3 4
