Pushrod tube sleeves?
#3089451
10/26/22 05:46 PM
10/26/22 05:46 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
What are you guys using if you use them? Does anyone offer a tube made for this purpose? Can you just completely grind out the PR bump and is it beneficial to do so? What about the spring bump? How far can you take it down? Eagle BGE 6.1 any different in these areas?
Re: Pushrod tube sleeves?
[Re: HotRodDave]
#3089598
10/27/22 10:40 AM
10/27/22 10:40 AM
Posts: 148 Albert Lea, MN
GTX5877
Albert Lea, MN
K & S Precision Metals thin wall brass tubing is what we have always used with good quality epoxy. They may have stainless also? Now my local ACE Hardware carries their product line plus I believe Hobby Lobby does. Tubing was originally used for building radio control airplanes.
1967 Dart GTS 426 Gen III Hemi 1968 Hemi Cuda 572 SS/AH Clone 1988 Chrysler LeBaron Coupe S/S 2003 Dodge Ram 1500 4dr SLT lowered 2012 Ram 1500 2wd Lowered 1970-1/2 Camaro Z-28 1974 VW Karman-Ghia
