Re: 99 dodge ram 2500 p/u vin tag decode
[Re: moparjo68]
#3089231
10/26/22 12:29 AM
10/26/22 12:29 AM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
[Re: moparjo68]
#3089313
10/26/22 10:36 AM
10/26/22 10:36 AM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
This looks like its for Ram Chargers. Couldn't find a place to put in VIN tag info the tag in your photo is not a VIN tag , that would be on the dash ... That said the VIN is on this tag . What exactly do you want to know ?
[Re: JohnRR]
#3089351
10/26/22 12:44 PM
10/26/22 12:44 PM
Posts: 487 Sonoran desert, Arizona, USA
moparjo68
I was wanting to know the breakdown, starting from the top, row's 1, 2, 3, 4, and 5. What is the code breakdown?
[Re: moparjo68]
#3089371
10/26/22 01:34 PM
10/26/22 01:34 PM
JohnRR
U.S.S.A.
I was wanting to know the breakdown, starting from the top, row's 1, 2, 3, 4, and 5. What is the code breakdown? Use the chart J body posted, looking at it will tell you what most of the codes on the tag are. Drop the last letter from what the chart has , you have 3 digits but the chart is showing 4 ... truck is black ? , V10 , automatic ?
[Re: moparjo68]
#3089464
10/26/22 06:18 PM
10/26/22 06:18 PM
Posts: 21,525 N.E. OHIO, USA
A12
N.E. OHIO, USA
Ok. I have found out what each code means on the tag except for one item: 459AE which is on line 3 from the top. Anyone know? PLUG YOUR VIN IN HERE: https://fcacommunity.force.com/RAM/s/equipment-listing IT WILL TELL YOU EVERYTHING YOUR TRUCK LEFT THE ASSEMBLY LINE down to the battery etc., Here's an example of a 1999 Dodge RAM 1500 info from a VIN I found online used truck sale:
