Page 3 of 5 1 2 3 4 5
Re: Found it!....Stupid Hemi [Re: Dragula] #3088464
10/23/22 03:28 AM
10/23/22 03:28 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Maybe I'm wrong but I've read that some Indy rockers, depending on when they were made, lack oiling holes.
The stock ductile rockers I'm using have an oil hole for the pushrods and the valve tip.
I'm running them with no restrictors and pushrod oiling. Still went from 20-50 to 5-30 oil due to high pressure.
I would think you could achieve what you need by adding oiling holes to your current rockers and removing any restrictors.
Aside from that, not sure of the exact details of your springs/setup but wouldn't usually correlate a dual spring with damper as a high end spring for high lift street use.
I like PSI ML springs with exceldyne locks/retainers for whatever it's worth.
Re: Found it!....Stupid Hemi [Re: INTMD8] #3093486
11/11/22 03:22 PM
11/11/22 03:22 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
So in mocking this up, I am wanting some custom ARP fasteners. I faxed over a quick CAD drawing of what I want to ARP, and then called them....Man are they backed up on custom orders....Like 6 months I am told....
So this may take all winter....
Re: Found it!....Stupid Hemi [Re: Dragula] #3093677
11/12/22 11:21 AM
11/12/22 11:21 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I know people that have had ARP studs on back order for a lot longer than 6 months.
2011 Drag Pak Challenger
Re: Found it!....Stupid Hemi [Re: rickseeman] #3095661
11/20/22 12:58 AM
11/20/22 12:58 AM
Dragula Offline OP
Dragula  Offline OP
So to fix an AFR problem on the Hemi, I had the slip fit header tubes welded up between snow storms....I will post pics when painted again...
Re: Found it!....Stupid Hemi [Re: Dragula] #3095674
11/20/22 02:43 AM
11/20/22 02:43 AM
I hope they still install easily luck
Re: Found it!....Stupid Hemi [Re: Cab_Burge] #3095730
11/20/22 11:11 AM
11/20/22 11:11 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
My Headers are welded and you will have to pull the bars on an E Body to get them out of the car but could just leave them laying around the bars when you pull a motor. Bartons stuff is very very nice. To me if 5 K fixes the problem and more research is needed before you spend the 5K for the Barton set up that is much cheaper than a costly repair to a set of heads or a complete motor. How much is in your motor now, so it is like buying an insurance policy. The spray bars need to be looked at and cleaned also. This type of motor like said above is really not built for the street. Even the 1966/7 motor had next to nothing for cam lift, 68/69 a little more and 70/71 went to Hyd.to make them live on the street. These motors need there yearly once over and checked. One other thing, I believe in a lot of Oil both quanity and quality and pressure/volume.Maybe not what a race motor will get in pressure but still a high number.This is not a quick fix untill the problem is nailed down to what has happened or your problem will reoccure again and again so make the change that will fix it once. It takes time so take that time withour any emotions to cloud your decisions. I say that because we all have been in a similiar situation and toss money that is not needed trying for a quick fix. Good Luck
1971 HEMI E BODY REGISTRY
Re: Found it!....Stupid Hemi [Re: Cab_Burge] #3095756
11/20/22 12:56 PM
11/20/22 12:56 PM
Dragula Offline OP
Dragula  Offline OP
They pop in and out, no problem....I have a MF front end....nothing in the way...
Re: Found it!....Stupid Hemi [Re: Dragula] #3095764
11/20/22 01:17 PM
11/20/22 01:17 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I welded up my Hooker Super Comp Hemi headers on my E Body also. I have a AlterKation from suspension so no torsion bars either.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Found it!....Stupid Hemi [Re: 6PKRTSE] #3096044
11/21/22 02:08 PM
11/21/22 02:08 PM
Dragula Offline OP
Dragula  Offline OP
Headers all repainted....between blizzards here.
Re: Found it!....Stupid Hemi [Re: Dragula] #3096265
11/22/22 10:44 AM
11/22/22 10:44 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Would have been a good place to install V band clamps. Could still take a couple tubes out for starter replacement.
69 GTX 68 Road Runner
Re: Found it!....Stupid Hemi [Re: JERICOGTX] #3096275
11/22/22 11:23 AM
11/22/22 11:23 AM
Dragula Offline OP
Dragula  Offline OP
I can pull the starter with just loosening the header slightly...It doesn't have to be removed, or any of the tubes...
Re: Found it!....Stupid Hemi [Re: Dragula] #3096318
11/22/22 01:59 PM
11/22/22 01:59 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Yes, same here. I can change my starter without removing the header. I did you V Band clamps on the collectors.
Re: Found it!....Stupid Hemi [Re: 6PKRTSE] #3096356
11/22/22 04:41 PM
11/22/22 04:41 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
5210 Super Comps? 2& 1/8" primary, 3&1/2 collector?
(just checking to see what I have to look forward to)
Rich H.
Esse Quam Videri
Re: Found it!....Stupid Hemi [Re: ZIPPY] #3096365
11/22/22 05:05 PM
11/22/22 05:05 PM
Dragula Offline OP
Dragula  Offline OP
Mines pretty easy to work on considering the big Hemi in there....
Re: Found it!....Stupid Hemi [Re: Dragula] #3096390
11/22/22 07:31 PM
11/22/22 07:31 PM
When I first saw this picture all those pipes it reminded me of snake mating season grin haha
Don't get weird when you get old, like me please whistling
Re: Found it!....Stupid Hemi [Re: Cab_Burge] #3096882
11/24/22 05:22 PM
11/24/22 05:22 PM
moparx Offline
moparx  Offline
HAHAHAHA !!!!! hey Cab, i think we are supposed to get weird when we get old ! panic laugh2
6PK, can you tell me where you got the turn downs for your race bullets in your picture, and what angle they are ?
a big TIA. up bow
beer
Re: Found it!....Stupid Hemi [Re: moparx] #3101105
12/10/22 04:29 PM
12/10/22 04:29 PM
Dragula Offline OP
Dragula  Offline OP
Just about ready to start testing....Need more parts. ..
Re: Found it!....Stupid Hemi [Re: Dragula] #3101241
12/11/22 11:03 AM
12/11/22 11:03 AM
NW Indiana
P
powertrip Offline
powertrip  Offline
P
NW Indiana
Smart and didn't cost you 5K, I like it! up
Hope this solves your spring problems, what springs have you gone with?
Re: Found it!....Stupid Hemi [Re: powertrip] #3101315
12/11/22 02:19 PM
12/11/22 02:19 PM
Dragula Offline OP
Dragula  Offline OP
I had Pacalloy and then Howards....It does not seem brand specific.....Would love a set of Bartons, but not in the budget right now....Hell, if this works, I don't even have to put a new cam I bought in it...
Re: Found it!....Stupid Hemi [Re: Dragula] #3101403
12/11/22 07:40 PM
12/11/22 07:40 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
[b][/b]
That header shot from the bottom is beautiful. Nice car for all the work you have put into it.
Old Geezer Racing
