Page 3 of 3 1 2 3
Re: Slow coronet [Re: RMCHRGR] #3088426
10/22/22 11:02 PM
10/22/22 11:02 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
as a reply to the basic questions you asked-
Yes to basic timing check.
yes to fuel pressure
replaced headers to eliminate leaks- no intake leaks
02 sensor is at an angle, like 18" downstream from merge of headers
Re: Slow coronet [Re: 8urvette] #3088437
10/23/22 01:43 AM
10/23/22 01:43 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Originally Posted by 8urvette
Naturally the data log didn't record. Of course. The dyno shows MPH and HP /TQ no rpms.
Would not hurt to post it anyway. If hp and torque scaling is the same they will still cross over at 5252.
Were you monitoring air/fuel on the dyno?
Everything you're saying about large additions to base fueling and going 14-15-1 on the street makes me think it's dropping fuel pressure.
Does the sniper monitor that?
I don't recall if you mentioned what your tank/pump setup is but it makes sense that a setup sensitive to slosh would perform fine on a chassis dyno and uncover the pump pickup under acceleration.
Re: Slow coronet [Re: CSK] #3088462
10/23/22 03:00 AM
10/23/22 03:00 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Originally Posted by csk
sorry about that !!!!!! I should have said,,, AND ,,, not BUT smile
No worries, all good smile And again I do agree but if we go off of what's been said, that it rolled 315/350 on a chassis dyno and then proceeded to trap 89mph....... it has to be down 150 crank horsepower or so?
I think a huge difference that -can't- only be attributed to a dual plane (in my opinion).
Still want to see the dyno sheet but it's soooo horribly far off my only ideas are-
-it has massive fuel pressure drop/starvation
-it burned a plug wire or 2, dropping cylinders which would result in false lean numbers on the wideband.
Most useful thing aside from the dyno sheet would be a data log. For whatever reason doesn't exist, should be easy to obtain.
Re: Slow coronet [Re: 8urvette] #3088496
10/23/22 08:36 AM
10/23/22 08:36 AM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Where do I start searching for more speed?
Look at your data.
Re: Slow coronet [Re: INTMD8] #3088498
10/23/22 08:57 AM
10/23/22 08:57 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Slow coronet [Re: A39Coronet] #3088507
10/23/22 10:28 AM
10/23/22 10:28 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
They will show up lean, the o2 sensor reads burned fuel not fuel.
OP what is the fuel pressure at WOT in 3rd gear?
The first thing you need to fix is the TPS at 80% at WOT.
Re: Slow coronet [Re: A39Coronet] #3088669
10/23/22 10:48 PM
10/23/22 10:48 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Originally Posted by A39Coronet
Two burned wires show a false rich condition, not lean
No, it reads all of the unburned oxygen and shows lean
Page 3 of 3 1 2 3
