Anyone using Starlink? #3088403
10/22/22 09:23 PM
10/22/22 09:23 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
Is there a way to keep my landline phones, modem and routers and get them interfaced?
I really don't like cellphones for voice calls. Besides I figure the stuff I have should be configurable.
Re: Anyone using Starlink? [Re: A990] #3089043
10/25/22 08:21 AM
10/25/22 08:21 AM
Garry Owen Offline
Garry Owen  Offline
There is an Ethernet adapter you can buy since the newer equipment uses proprietary connectors. I added a router to mine add more functionality. I’m unsure about your landline but everything else should work fine with it.
Re: Anyone using Starlink? [Re: Garry Owen] #3089077
10/25/22 11:28 AM
10/25/22 11:28 AM
East Bay, N. Cal.
calmopar Offline
calmopar  Offline
East Bay, N. Cal.
Is your landline VOIP? If so, use the above advice. If you need one, look into OOMA or others - you can move your landline # over. Make sure whatever service you use allows you to properly register your address for 911.
Trying to enjoy life!
Re: Anyone using Starlink? [Re: calmopar] #3089135
10/25/22 03:27 PM
10/25/22 03:27 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
Thanks!
