67 - 69 Barracuda battery disconnect #3087247
10/18/22 06:11 PM
10/18/22 06:11 PM
Chicago-area Illinois
4mopower Offline OP
4mopower  Offline OP
Where did you guys come through to the Outside to place the disconnect switch?
Any help with ideas and pics!
Thanks everyone
John
Re: 67 - 69 Barracuda battery disconnect [Re: 4mopower] #3087261
10/18/22 07:39 PM
10/18/22 07:39 PM
Kansas
Thelma133 Offline
Thelma133  Offline
Kansas
I have 67. Will try and take pic and send it to you.
Re: 67 - 69 Barracuda battery disconnect [Re: 4mopower] #3087272
10/18/22 08:20 PM
10/18/22 08:20 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
Not a great picture, but my disconnect handle comes through on the right hand side just above the bumper. See the red handle - the battery and switch is just inside the trunk on that side. (Push / Pull Switch / Rod combo)
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: 67 - 69 Barracuda battery disconnect [Re: 19swinger70] #3087297
10/18/22 09:34 PM
10/18/22 09:34 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
For me, it's a decision on whether to drill the body, or use a tail lamp or (for some Barracudas that have them) a back-up lamp like the car above.
On a '68 Road Runner, I went through the back-up lamp lens and used a rotary switch.
On an early B, I made a bracket that attached to a bumper bracket.
My Duster already had a hole below the trunk lock from its SS days, was never - and never will -be a street car or a restored #s car, so that was easy.
If there's an opportunity to be clever & artistic, I try to take that route - as long as it doesn't confuse or irritate the Tech guys.
Re: 67 - 69 Barracuda battery disconnect [Re: topside] #3087350
10/19/22 12:46 AM
10/19/22 12:46 AM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Here’s mine on my ‘68
"Any fool can know. The point is to understand"
- A. Einstein
Re: 67 - 69 Barracuda battery disconnect [Re: EvilB1Dart] #3087352
10/19/22 01:20 AM
10/19/22 01:20 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
There is a factory hole here, and that is what I used.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 67 - 69 Barracuda battery disconnect [Re: BloFish] #3087471
10/19/22 12:58 PM
10/19/22 12:58 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Hard or next to impossible to see but it is under the bumper on the pass side. I suppose if you squint hard enough you can see the silver painted knob and lettering on bumper, but probably not. So here is a gratuitous picture anyway laugh2
Re: 67 - 69 Barracuda battery disconnect [Re: 19swinger70] #3088259
10/22/22 10:21 AM
10/22/22 10:21 AM
4mopower Offline OP
4mopower  Offline OP
19Swinger70 -
Looks to be enough room between the bumper and tail lamp. I was wondering that.
Thanks for the pic.
Re: 67 - 69 Barracuda battery disconnect [Re: BloFish] #3088260
10/22/22 10:25 AM
10/22/22 10:25 AM
4mopower Offline OP
4mopower  Offline OP
BloFish -
Is there enough room to get your hand in between the bumper?
I currently do not have the bumper mounted.
Thanks.
Re: 67 - 69 Barracuda battery disconnect [Re: Al_Alguire] #3088261
10/22/22 10:30 AM
10/22/22 10:30 AM
4mopower Offline OP
4mopower  Offline OP
Yes it is very hard to see going that fast....Awesome paint though!!! Car looks fast!
Thanks for the dream! Lol.
Re: 67 - 69 Barracuda battery disconnect [Re: 4mopower] #3088280
10/22/22 11:28 AM
10/22/22 11:28 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Originally Posted by 4mopower
BloFish -
Thanks.
Yes, it is just below the bumper. I use the Moroso cut off switch.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 67 - 69 Barracuda battery disconnect [Re: BloFish] #3088317
10/22/22 01:49 PM
10/22/22 01:49 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Here is mine.
68 Barracuda Formula S 340
Re: 67 - 69 Barracuda battery disconnect [Re: 4mopower] #3088400
10/22/22 09:04 PM
10/22/22 09:04 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
Dumb question, but does anyone know if the switch must be labeled? So far it hasn't been an issue for me, but just trying to stay out in front of anything
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: 67 - 69 Barracuda battery disconnect [Re: metallicareload] #3088491
10/23/22 08:04 AM
10/23/22 08:04 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
It is supposed to be. Mine is not and sometimes that gets mentioned in tech. I usually write PUSH with a sharpie on the bumper about once a year and it makes them happy. Maybe someday I will put a sticker on there.
