Re: Edellbrock RPM intake
[Re: GTXMEX]
#3086280
10/15/22 02:34 PM
10/15/22 02:34 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
Don't do that , buy a correct one for your heads
[Re: GTXMEX]
#3086283
10/15/22 02:42 PM
10/15/22 02:42 PM
Posts: 3,024 NY
B1duster
NY
[Re: GTXMEX]
#3086288
10/15/22 02:52 PM
10/15/22 02:52 PM
Posts: 3,024 NY
B1duster
NY
I believe as cast it’s stock port, but it has larger runners and they charge $100 to cnc the ports to max wedge size. Same deal with modman
[Re: B1duster]
#3086300
10/15/22 03:30 PM
10/15/22 03:30 PM
fast68plymouth
So. Burlington, Vt.
The Indy 440-2D basically has MW sized runners internally....... that are filled in/shrunk down to std port size down by the gasket surface.
Imo, they’re a pretty good choice for a BBM with MW heads........that needs something that will fit under the hood.
That being said, I can’t really imagine a stroker BB having many drivability problems with a std port single plane on it.
TF used the Track Heat manifold for their 505” test mule combo, saying it’s “port matched”. Be interesting to see how close that port match was....... and how far up the ports they went.
