HEATER BOX RESTO #3085756
10/13/22 01:16 PM
10/13/22 01:16 PM
Sweden
71redcuda Offline OP
Sweden
Hello,
I would like to know if anyone can point me to a good resto guy that
restores heater box to OE level.. its for a 70 E-body.
I know Mike Mordarski once did it but not anymore i think.
Nicklas
Re: HEATER BOX RESTO [Re: 71redcuda] #3085771
10/13/22 02:33 PM
10/13/22 02:33 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
If its a non AC box no one would risk shipping that. Undamaged, those are IMPOSSIBLE to find and if you do they are worth over $1500. I know Mike would never ship a box. Not even local.
AC boxes are a dime a dozen but are also easily damaged. IF shipping removre ALL the heavy parts and ship separate from the fragile plastic housing; evap, core and blower motor.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: HEATER BOX RESTO [Re: 71TA] #3085786
10/13/22 03:54 PM
10/13/22 03:54 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Farm out the blower motor rebuild and do the rest yourself with the gasket kit from the 71TA (DMT). You can have the part number stamps made, or buy them I think.
I have bought two used heater boxes online and both showed up damaged from shipping monkeys. Found one at a local parts hoarder guy's place and bought it in person.
Re: HEATER BOX RESTO [Re: Neil] #3085789
10/13/22 04:00 PM
10/13/22 04:00 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
If yours is still ok . . . you should be able to clean it up and redo yourself . . . as said above, the gasket kit from DMT (71TA) is absolutely perfect ! I did my own on my Sport Satellite - AC car . . . cleaned up great, even the stamped part numbers were still there and very visible !
Good luck
Mark
Re: HEATER BOX RESTO [Re: a12rag] #3085793
10/13/22 04:27 PM
10/13/22 04:27 PM
Sweden
Sweden
Yes.. maby thats the way to go.. i have a restored motor from Bill Meerholz to use..
But the plastic is no good . So need to fix that + all gaskets.
Thanks for all replies.
Nicklas
Re: HEATER BOX RESTO [Re: 71redcuda] #3085859
10/13/22 10:42 PM
10/13/22 10:42 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Nicklas
That plastic is the key to restoring the box. The rest is easy the box itself cannot be repaired. You would have to repaint it black which is not correct.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: HEATER BOX RESTO [Re: 71TA] #3085866
10/13/22 11:57 PM
10/13/22 11:57 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Shipping it International, you have to have it crated at least.
Then there's the costs to ship both ways? Can only imagine that.
And then hope it doesn't get damaged on either trip overseas?
Re: HEATER BOX RESTO [Re: PhillyRag] #3085867
10/14/22 12:00 AM
10/14/22 12:00 AM
Sweden
Sweden
Yes.. you better belive it easier to restore/buy parts within USA.
Its for this aar cuda
https://www.garaget.org/mypage/?page=gallery&user=106330&album=62026
Re: HEATER BOX RESTO [Re: 71redcuda] #3085883
10/14/22 06:05 AM
10/14/22 06:05 AM
Virginia
larry4406 Online content
larry4406  Online Content
Virginia
Nicklas
Mike Ross (HEMICUDA) from BEA repaired one with plastic repair and duplicated the fiber appearance as well. The results of which were once documented on another site (the OP of that thread sadly deleted the thread and the info is lost).
